Changing tranny crossmember w/out dropping tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Oct 30, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    This won't harm anything will it? 400 tranny/208 case, I have to put in my old crossmember since the new one doesn't clear the front driveshaft. Just wanted to ask so I don't mess anything up.
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    No, it shouldn't hurt anything. You could put a jack under it if you're worried, but the motor mounts and t-case crossmember will hold it up while you remove the tranni crossmember.
    Thomas.
  3. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Uhh-oh, my transfer case crossmember is missing, I've got a crossmember where the tranny and t-case mount together, nothing else. But I'll use the jack just in case. Thanks
  4. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    no, thats right...just put a jack under the rear snout of the t-case and it'll be all good.
  5. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    I would support either the case or tranny (as close to the middle as possible) if you're not taking out the adapter.
    If you are taking out the adapter, that's a different (more complicated) story.
  6. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    No problem doing this. This past weekend my transmission was held up with a jackstand for a day until I could get the crossmember in place with the new tranny mounts. I have the back crossmember, but it doesn't support the t-case (I assume this is normal). There is a gap between the back of the NP203 and the crossmember and it does not touch. The only support is both sides of the engine and two mounts where the transmission and t-case match up (under the adapter).
  7. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    DOH! What was I thinking? LOL ... yea, ummm .... that's right, there's only one crossmember under there /forums/images/graemlins/tongue.gif
    I agree, support it with a jack. I just removed mine on Saturday when I lowered it. I just put a jack under the back of the t-case and it was fine.
    Thomas.
