charcoal canister...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Mar 12, 2005.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    is there any reason I can't remove this thing? My city only does the sniffer test on emmissions day, and I know this canister isn't doing jack. I have no inner fenders anymore and I wanna narrow my front clip too... this canister POS is in the way, and the lines that lead to it might get ripped off my a big tire at full flex...
    anyway, if removing it is no big deal, is there anything special I need to do with the various hoses that go to it or can I just plug 'em?
    j
  2. dyeager535
    26,980
    The problem is in venting the tank. Plug that and your tank will build up pressure and/or vacuum.
    *IMO* it's best to work with it, as it PROBABLY helps keep condensation in the tank down better than a simple vent, and should be more water resistant for you guys that do deep water fording.
    On my car, I hooked the line right up to vacuum on the carb, but I don't know as I like that idea anymore. Perhaps with a check valve that would be ok.
  3. wfotyme
    wfotyme Registered Member
    Oct 29, 2002
    17
    Fresno, Ca.
    Does the Charcoal Canister rob any horse power from a smog exempt engine?
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh its the vent for the tank, doesnt rob any power that I know of. If you do remove it, you probably need to put one of those little checkballs on the end of the vent line, so that if you roll your truck offroad (I mean come on you are narrowing it afterall), you wont have gas spilling out of the vent.
  5. dyeager535
    26,980
    In actuality, it will help your economy, you are burning the fuel that would otherwise be vented into the atmosphere. :waytogo:
  6. AllamericanK5
    AllamericanK5 1/2 ton status
    Feb 2, 2005
    131
    Colorado
    yeah mine was fubared and i pulled it out and pluged the lines till i could find a new one. Well one drive to work and i relised that wasnt the thing to do my gas tank sounded like it was going to explode i opened the gas cap and it sounded like i was draining the air compressor. anyways i would just try to work work around it and if you plan on geting emissoms agian because i mad that mistake and i have to put every thing back on
  7. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Thats what I did with mine. I haven't had any problems.
  8. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Move the canister. Put it up on the firewall or something. I know it looks like ****, but my truck runs better with the smog stuff on. I have a completely stock engine though.
    I'm surprised that WA doesn't do more with all the earth muffins up there. They do visual and sniff down in AZ.
  9. dyeager535
    26,980
    Nope, WA does it the way all inspections should be....doesn't matter how you pass, if you pass the sniffer, you are done. :)
    (or at least it used to be that way, haven't gone through an inspection in 5+ years)
  10. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    Depends where you are in AZ. In Mojave County they dont' care what you do. Needless to say my truck has ZERO smog items on it!:D
  11. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    i removed both of mine and ran new vent tubes to the top of the firewall near the brake booster. Probably should do the checkvalve thingy but havent considered rolling quite yet.
