Charging problem...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Aug 14, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Anytime I turn on my A/C, or anything for that matter, my gauge for charging drops below 13, with A/C it goes down to about 9. Even hitting the brakes makes the gauge drop a little when the brake lights turn on. The gauge drops more as the engine gets hotter. What could be causing this??? I have a new alternator on the thing and it did this before I put it on and it still does it.
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Do you have the correct amount of amps? Also check your wiring for the guage and the charging system. You could have a drain you are unaware of.
    Try reving it up with the A\C on and the brakes and see what it does. Chances are its the wrong alternator (not enough amps), a drain, or insufficient wiring like the guage of the wire is to small or other faulty wiring.
    Good luck
  3. dyeager535
    26,975
    Don't automatically assume the gauge is correct.
    Obviously the brake light/draw is a problem, but measure voltage at the alternator or battery, (should be over 12V in all cases) to make sure the gauge is reading accurately. If it's not accurate, its no problem, you just have to be aware of what is "normal" and when that changes, you've got problems.
