charging problems
Discussion in 'The Garage' started by bryguy00b, Mar 23, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok so i replaced the altinator a few days ago cause the system wasnt chargin right, but now its still not with the new one on there. belt is nice and tight, checked voltage, i get like 11.50 or so to everything when the key is off, with it on, i get like 12.80 at the battery, and 13.40 or so at the cable going to the altinator. and like 12. something at the plug, any ideas? seems like the altinator is putting out enough voltage..
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    maybe the battery is dead or going. Buy a new one and save the receipt in case it dies , you can exchange it.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm..i dont think thats it though to be honest, ill ask my dad, im not sure what it could be really im pretty lost..theres not any fuses that have to do with it or anything is there?
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    bry... have you let it run long enough to burn in the brushes in the alternator? its a possibility you got a bad alternator also..
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Check the connections at the battery, the starter and grounds and make sure they are all nice and clean. That's just about it cept for a tired battery. Good luck to ya in the future.
    Allan
  6. justhorsinaround
    Sep 16, 2003
    6,798
    Check the connections at the battery, the starter and grounds and make sure they are all nice and clean. If you have the molded plastic with the chargin wire comin from the alternator in it check that especially cuz that's a hard one to tell. I chased a problem like this on a Burban we owned and I couldn't figure it out until that wire came right out of the plastic due to corrosion. That's just about it cept for a tired battery. Good luck to ya in the future.
    Allan
  7. justhorsinaround
    Sep 16, 2003
    6,798
    Hmmm that was weird
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Charging system sounds fine. Battery isn't holding a full charge. Alternators usually put that many volts anyway (most auto electronics like CB's prefer 13.8 volts anyway). If you can afford it go optima, otherwise go down to the parts store and get a 5 yr battery /forums/images/graemlins/k5.gif
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    but if the battery was bad would that bring the altinator down? cause on the meter it never gets up to around 13 were it should be its usually down around 8-10
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    by the way thanx for all the help so far!! /forums/images/graemlins/thumb.gif i dunno what id do if it werent for this place lol..
  11. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    If you are having trouble starting the engine, the battery could have a bad cell in it, you will still get a 13 volt reading from the volt meter, but when it loads up trying to start the engine, they will usually drop to nearly nothing, You need to check the load on the battery. You will still get full power from the alternator, but the battery isn't going to "keep" it. Get that battery checked out, BTW, how old is the battery??? /forums/images/graemlins/thinking.gif
  12. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    dunno..my dad got it from work..but would that explain why the volt meter stays down around 8-10 (veries sometimes) and never gets up to 13 like it should and stay?
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok no one has answered this direct question i have yet..anyone!!?? comonnn..
  14. 4xcrazy
    Oct 31, 2003
    9,472
    5
    If you are talking about the gauge on the dash, it is a very good possibility, but those gauges are kinda unreliable as not one of them from truck to truck will read the same, just go get the battery checked out and see where it stands.
  15. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well ill switch it when i get home then and see what happens
  16. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok well i switched another batteyr in it and it seems to be fine now guess thats all it was /forums/images/graemlins/thumb.gif
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thats what I thought it was. Watch it for a week or so and let us know if its ok. /forums/images/graemlins/thumb.gif
  18. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    sure thing! thanx! /forums/images/graemlins/grin.gif
  19. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif
  20. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
