Cheap 86 sub 3/4ton in NH 600$
Discussion in 'Complete Vehicles' started by 6.2puller, Apr 11, 2006.
  1. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    1986 chevy suburban 3/4 ton
    350 motor TH400 tranny, 208 case.
    10bolt front 14bolt SF rear.
    Motor runs strong, valve seals leak a bit, smokes for first 2 min after sitting. Exhaust leak arount the header collector and gasket. Rest of the drivetrain is good. Ball joints need replacing and are included.
    35 12.5 16.5 BFG ATs kinda ruff.
    Now the bad, rockers are rotten. Rear floor has a hole and the section under the tailgate is rotted as well as the bottom of tailgate itself. I have the pannel that goes under the tailgate, brand new goodmark pc. Bottoms of all 4 doors need work. Rear doors really need work.
    600$ as it sits.
    Can deliver for 1.00$ per loaded mile. 500mile max.
    For 1000$ you can have this truck with 4 replacement doors that are in great shape from down south. A jimmy tailgate that is repairable and a Jimmy hard top with one borken window. My original goal was to fix this up and make it a removable top model. Unfortunatly my goals in life are different now and this is gotta go. [​IMG]
    For 1200$ it will come with a much stronger running 350 that does not smoke. [​IMG]
    Contact me at nateniki@adelphia.net for more info or questions.
  2. 79silverado
    79silverado Registered Member
    Nov 7, 2004
    61
    Rhode Island
    Do you have any interest in selling the goodmark rear support beam or doors seperate? Are they pw/pdl and/or tinted glass? Any pics of em?
  3. 6.2puller
    Jul 8, 2004
    569
    New England
    If the Burb sells without them then I will but not now. I might hang on to the rear doors though cause they will fit the 3+3 also. :D
  4. 6.2puller
    Jul 8, 2004
    569
    New England
    BUmp, gotta move this thing, 500OBO, make offers.
  5. 6.2puller
    Jul 8, 2004
    569
    New England
  6. 6.2puller
    Jul 8, 2004
    569
    New England
    going to part this out so if you want anything post up
