Cheap A$$ Guage install
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by HIX, Mar 6, 2003.
  1. HIX
    HIX Registered Member
    Feb 26, 2003
    80
    Denver
    Don't hate me cause I'm Cheap!
    I added swapped out the oil, amp, temp guages and added the tach to one of the open ones. It wasn't pretty but it will get the job done. 50 bux for the guages is alot cheaper than the 200 plus for the remakes. [​IMG]
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    looks great /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Where did you get the tach?
    I have never seen one that small.
  4. gallup
    gallup Registered Member
    Sep 24, 2002
    8
    Ozark Booneys MO
    Looks great, what brand of gauges did you install?
    Did you try to find a tach that would fit the larger center location on the bezel? That would be easier for my old eye's to read at a glance! I thought about doing this, just not on top of the list of things to do next.
    Mike
  5. vaulter
    vaulter Registered Member
    Mar 3, 2003
    15
    texas
    Yeah, where did you get that tach?
    vaulter
  6. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    looks like they are the sunpro gauges, they are usually pretty cheap, can find them at pepboys even. I am going to do the same but am going to get an autometer in dash tach for the stock tach area, I bet you could find one for cheaper than autometer though and make it work. I know Steve chin used one out of a late 70's firebird or camaro I think.
  7. HIX
    Feb 26, 2003
    80
    Denver
    The reson I got the small tach is due to the fact that you would have to cut the circut board in order to make them fit in the tach area as most tachs are deeper than the back of the dash unit. The small one fit in well. When I decied to buy new gauges I went the cheap rout b/c I think I have alot more repairs to do on this truck.
  8. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    The install looks great!
    Just to tell you. Me and a friend bought Sunpro gauges and me and him both got bad tempture gauges.
  9. Roostr84
    Aug 19, 2000
    451
    NJ
    Yeah I had a brain fart. I was assuming you were changing the speedo too and wouldn't need the circuit board. I am trying not to invest too much in gauges however I want something that can take a little bouncing around. My rig is too beat up for me to justify buying a really nice set. Looks good though. Let us know how it works out.
  10. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Yeah, I used a modified '77 Camaro tachometer. I also modified the circuit board to reduce wiring headaches.
    http://www.geocities.com/MotorCity/Downs/1963/BlazerPix.html
    I prefer the near-stock look that it has. It fits in pretty well with the stock gauges (although I'd have liked it if the numbers and letters on the tach had that slight green tint that all of the Blazer gauges have).
    There is something wierd about the close-up picture in that the tach needle appears much more red than it is. I painted all of the needles with the same paint at the same time, and they're all the original orange-red color in a 60% semi-gloss.
    Oh, hey, see where my fuel gauge was reading? That's from the open circuit between the gauge and the sender. Reads *way* over-full.
