CHEAP carpet heat shield and sound deadener padding
Discussion in 'The Garage' started by adamforsythe, Feb 1, 2007.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I am after a good cheap heat shield and sound deadener padding for my k5. Where did you guys buy yours? I found 4' by 6' rolls on ebay for 30+ shipping.
    Adam
  2. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Lowes carries the same stuff in the roofing section. I think the brand name is Peel & Stick. There is a lot of info in the Audio section.
  3. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    X2. I used that stuff all over my truck. Some 3M spray adhesive on the back and your good to go.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've used the stuff that is just under a half inch thick before. It's sort of a felt like padding with aluminized plastic on one side as a heat shield. Bought it at Pep Boys for $24.99 a few years ago. Don't use it if you'll be getting water inside though. It will soak up liquid like a sponge. It's the same stuff as shown here. If you need a lot, it's cheaper to buy the larger roll instead of several smaller ones.
    I think grimjaw and chalet2506 are talking about the rubber membrane roofing material that works sort of like Dynamat for deading noise. Good stuff for noise reduction, but it doesn't do much to keep the heat out (or in). Several folks have used it with good results.
  5. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    Believe it or not I have heard of bed liner sprayed 1/4 inch thick though out the tub works. I haven't tested it, but it would be kinda pricey. Don't know how well it will repel heat but it might deaden the sound. Also why not rob a bunch of heat shields from junkyards? They seem ply-able enough.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    http://www.edesignaudio.com/edv2/index.php?cPath=24
    someone on here pointed me to that company a while ago. They have the liquid stuff, and varying thicknesses of the normal kind.
    I used the EDead V1(all the way at the bottom) and did my entire Saturn with it. Just door panels and lined the trunk. $40 for 40 square feet, couldn't beat that with anything.
    I need ot get more and do the inside of my pickup, but I want to replace the vinyl floor and do the floors at the sametime.
  7. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    I bought eDead off Ebay before I found the roofing stuff. They appear to be the same thing.
  8. chalet2506
    May 9, 2006
    4,931
    Skeddadlin
  9. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Links and pics are good.
    Adam
  10. adamforsythe
    Oct 16, 2004
    1,394
    Maine
