cheap easy power tip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Nov 12, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    at least i hope... or am i an idiot for believing this? /forums/images/graemlins/crazy.gif
    my shop foreman told me today that i could run the hose from my windshield washer tank into a hole that i would have to drill in my air cleaner and put a sprayer nozzle on the end inside the air cleaner and fill the tank with straight alcohol. and when i want more power i could just hit the wipers and VROOOM!! so am i retarded or could this work? and if it did work would it destroy my engine? /forums/images/graemlins/crazy.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Interesting idea. /forums/images/graemlins/thumb.gif I suppose it could work. I'm assuming alcohol...like "alcohol fueled dragster" right?
    What will you do when your windshield is dirty /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
  3. blwnbwtie
    blwnbwtie Registered Member
    Jun 4, 2002
    72
    LA California
    sounds like it might work not sure though, but if you get the ambition to try it let us know, cheap NOS i guess?/forums/images/graemlins/k5.gif
  4. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    my feelings on that are not to do it. try it on a lawn mower or something. if you ad more fuel to a mixture, and not more air, then it is going to be rich, and rich is slow. also alcahol has different burning properties than gassoline, it may make a lean condition, if so and you are running regular gas, and under a load, and say the timing isnt right on. your going to get detoantion in a bad (break something expensive) way. just my .02. if you try it let us know.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Ummm, sounds like a good test write-up that you could do.....
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Basicly you add alcohol to gas to slow down the burn to prevent pre detonation (pinging) Alcohol is not as flamable as gas it has a lower flash point.
    If you have a high compression/performance engine. Mixing gas and alcohol (methanol) makes the gas burn cleaner and cooler without pre-detonation so you can run more timing advance than with just gas alone. This allowes you to make more power. But you usually need to tune the carb and increase jet sizes to richen up the fuel ratio or you will burn valves real fast
    In a basicly stock engine adding alcohol wont do a whole lot. You could tune your engine for it and add more total advance to make more power but you are risking breaking or burning something If you dont know what is going on.
    Speaking of burning /forums/images/graemlins/angryfire.gif Running a flamible liquid thru your windsheild washer system into the air cleaner sounds like a great way to burn down your rig
  7. muddysub
    Jun 23, 2001
    10,452
    489
    Speaking of burning Running a flamible liquid thru your windsheild washer system into the air cleaner sounds like a great way to burn down your rig
    [/ QUOTE ] true /forums/images/graemlins/crazy.gif i don't think i'll do it.
  8. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    No, you're not an idiot but I think you'll be disappointed if you try it.
    Alcohol injection (actually a mixture of alcohol and water) has been experimented with since the 30's and 40's when the military used it on forced induction (supercharged) engines to reduce detonation at higher boost pressures.
    Alcohol injection does 2 things:
    <ul type="square">
    [*]First, the rapid evaporation rate of alcohol will cool the intake charge to allow more air/fuel mixture into your combustion chambers. Nitrous Oxide also cools the intake charge and provides the same benefit, although Nitrous evaporates MUCH faster and cools the intake charge MUCH more.
    [*]Second, adding alcohol will effectively raise the octane rating of the air/fuel mixture. Now, before you get all excited, a higher octane rating ONLY means that the charge will burn slower, reducing detonation. If you run the alcohol injection all the time ($$$$$$$$$) you COULD advance your timing a few degrees and get a few more ponies out of your engine.
    [/list]
    Compared to Nitrous Oxide .... well, there really is NO comparison other than the fact that they both cool the intake charge. The bigest advantage of Nitrous is the fact that it contains OXYGEN that is released when it is vaporized. That is why you also have fuel nozzles with a nitrous system, to add more fuel. Thats where the power comes from.
    Bottom line: After plumbing everything, messing with your timing, buying alcohol (about $5.00/gal) and adjusting the contraption to work properly, you MIGHT see a TINY change in horsepower due to the cooler intake charge.
    I realy wouldn't recommend installing it on a daily driver but if you drive a Big Block Suburban over the mountains everyday with a 10k trailer hooked on the back, alcohol and/or water injection would be a great idea to help control detonation on those long uphill runs.
    If you do try it .... show us the pictures!
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    The 'real' way of doing that is carb cleaner can in the truck with a tube running into the air cleaner lid. When you want a boost you hit the spray nossle on the can...
    My uncle use to drag race with that setup.
    Good luck running alcohol threw an electric motor let me know how that turns out /forums/images/graemlins/thumb.gif
    Jeremiah
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    By the way, alcohol also contains O2 like Nitrous, the difference is the percentage, but as both of you said, you have to modify your engine to get the power out of the alcohol, and you will still burn your engine fast because alcohol is a great oil cleaner, so it will clean your cylinder walls and burn the rings.
    Also the fact tha alcohol (unlike nitrous) is on it's own flamable, so do you want that under your hot hood.
    I think not.
    But keep bringing ideas guys, someday we will find cheaper ways tod o things. /forums/images/graemlins/thumb.gif
  11. muddysub
    Jun 23, 2001
    10,452
    489
    well i guess that was a bad idea, i'm not gonna try it. /forums/images/graemlins/crazy.gif
  12. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    not a bad idea, but i dunno if i would want it in my rig, i have always thought about something along these lines but never had the cahonies to install it, instead of alcohol i was going to insert some of my Nitro Methane from my RC car /forums/images/graemlins/smile.gif hehehe nothing like a little 30% boost to get ya going, the only thing is the RC fuel has a oil in it and i was not sure about the mixing of Castor oil into the intake, but who knows, maybe ??? maybe not i still might do it about the time i have money for another motor, hehehe
    if ya try it let us know /forums/images/graemlins/smile.gif
    thanks
    Ck1500 /forums/images/graemlins/ears.gif
  13. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    In moderation it would be similar to water injection. In small amounts water is a good thing for a motor. Cools the intake air and helps reduce carbon. The alcohol would just cool the air more because of how fast it evaporates.
    I hardly think its worth the effort, even for as simple as it is. Youll never get a nitrous kick if thats what your thinking.
    I dont think it would be harmful,(in moderation) but I dont think it would help either.
  14. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    ok well i thought of a what if question. What if you took rubbing alcohol and poured it down your gas tank? would anything happen? my friends joke that you could make the engine burn hotter and mess it up, but im not really sure if it would do anything.
  15. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    One other thing we use to do on hot nights drag racing is ICEE, NOT ICE. You know the Plastic blocks of ice you freeze to pack in a cooler? Place one on the opposite side of the intake port on the air cleaner (not inside the air filter), it cools and adds moisture to the air. We use to wrap the fuel lines in the flexable ICEE packs also (you can buy the fancy canisters to route the fuel lines through that have the water drains but they are $60+).
    I wouldn't drive around with one in, but we use to drop it in long enough for a quick run.
  16. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You don't want to put alcohol in your tank, it will get moisture and make it rust. /forums/images/graemlins/thumb.gif
  17. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Alcohol is the main ingredient of aftermarket products to remove water in the fuel tank that accumulates from condensation. It absorbs the water molecules and carries them out to be combusted. So its a good thing to use occasionally.
  18. dyeager535
    26,980
    Won't help performance, but since the burn is cleaner, up to about 25% rubbing alcohol to gas mix can help you pass emissions. (same idea as the stuff on the shelfs selling for what, $5-10 a can?)
  19. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    putting alcohol in your gas tank is not a good idea trust me ive tried it i put denatured alcohol in a car i had and it removed all of the varnish film from inside the tank and fuel lines and put them into the fuel filter. 4 filters later it was fine
