Cheap(er) Hummer beadlock O-rings UPDATED!
Discussion in 'The Garage' started by grimjaw, Mar 23, 2007.
  1. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    There are two different 12 bolt wheels, the one with the alignment hole (which has a higher weight rating) uses a thinner red O-ring and the other one uses a thick black O-ring. They look the same other than the newer one has an alingment hole (if the vale stem is at 6:00 the hole is at 3:00. The first 12 bolt wheel is rated at #3400 and the one with the alingment hole is rated at #3850. The one I have listed are for the older rims.
  2. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,558
    1,487
    the armpit of the east coast, 08046
    thanks. i just scored a set of tires/wheels off of greedbay. i was wondering where to get the o-rings.
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    nice find.... I'll be getting some of those
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    have you tried them out yet and verified they work good? i need some of those as well
