cheap headers...
Discussion in 'The Garage' started by 84gmcjimmy, Jul 13, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey, sometime in the fall/winter I will be swapping in a pontiac 455 that I bought off of kennyw. To increase the stock power, I was going to buy some headers for it. I don't want to pour a bunch of money into them as I will only have this engine for a couple of years. So my question is, do you know of any headers for a pontiac 455? I found these off of JEGS (scroll to the bottom, look at pontiac GTO-455ci) and they are around 170 bucks. I've seen some cheaper, but don't know where. Or, is there any other engine that has the same mounting as an 455 would? Thansk for your help /forums/images/graemlins/thumb.gif
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    A GTO has a different shaped frame than a blazer....you will probably run into problems with headers that will fit.
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    eek. So your telling me I can't use headers /forums/images/graemlins/eek.gif
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Do some good measuring. Keep into account things moving from flexing, a/c brackets, etc... and them shop for headers based on that. You may need to get out something and trim the collectors to fit the engine if you find some to fit in length/width. My bet is you can get cheap headers but you may need to do some homework first. I also suggest if you do end up with some cheaper headers, get some nice gaskets so they will seal correctly.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    call up jeggs, the tech support there rocks!! they actually knew stuff about my mini, annyway they should be able to give you some good info as to what will work for your app. Also it will hlep you help them if you do like steph said and take some good meaursurements before you call them /forums/images/graemlins/waytogo.gif
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Steph, my original plan was to get everything on the engine first, (i.e., the headers) and then install it. So if I did do that I wouldn't be able to measure or anything. I guess I am stuck, or install the engine and then get headers after measurements /forums/images/graemlins/dunno.gif
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    It's much easier to install the headers when the engine in the truck. Now that I think of it, it would be a HUGE pain in the ass to install an engine with headers and not ding them all up... /forums/images/graemlins/thinking.gif
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    oh, seriously? I will install the engine first then /forums/images/graemlins/doah.gif
  9. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You can try to install with headers, but yeah, I think it would be a butt. You really don't know what you have room wise right now. If you order something up, then damage it finding out it's too big or small, then what? You are stuck.
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, I will just wait until I install it. Then I will take measurements, and try to match it up with simular headers. Thanks /forums/images/graemlins/waytogo.gif
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]With some frames the headers at the head flange are wider than the frame rails and the tubes bend inwards making the width narrower to clear the frame...basicallyin some apps it is impossible to install the engine with the headers attached.
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Oh, i just thought that you could install them attached to the engine, before the engine is installed because I saw someones picture of there engine on an engine stand with the headers on. I guess they just put them on for the picture.
    Thanks for all your help /forums/images/graemlins/thumb.gif
  13. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there was a 69 cutlass that had a 455 with headers. from what it looked like, the headers would fit on a truck, you may have to get different linkage brackets. but im sure you can make something fit.
    i wouldn't spend to much on a set, you mey get them and not be able to get them to work and not send them back. check swap meets and ebay look for some cheap used ones. then when they rust through or what ever you know what you need to buy. just an idea /forums/images/graemlins/waytogo.gif
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Chevelle headers will fit a truck no problem, i dont see why GTO headers would be any different.
  15. jhama78
    jhama78 Registered Member
    Feb 12, 2003
    34
    VA
    We just put a 68 poncho 400 in a bud of mines 76 k5 and ended up using gto headers (im pretty sure) and they fit like a charm. Ill try and get pix this weekend for ya.
    l8r
    -j-rOd
  16. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I don't know if anyone makes shortie or block hugger headers for that engine. You might be able to fab up a set, there are also kits to build yourown.
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    When you say kits to build my own, what comes in the kit? Pre bent tubes ready to be welded toggether?
  18. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Whats so bad about the stock manifolds??. /forums/images/graemlins/dunno.gifI know headers give more power,but they rust out fast,are noisy,and they could be a big pain to make fit,if they wont work your stuck with them--the swap meet idea is a good one if you feel you must have them,you wont lose as much that way if it doesnt work--its cool that someone here has already "been there and tried that",thats the beauty of this site!.I think the stock pontiac manifolds would fit better(as long as they dont dump in the wrong spot)they hug the block real close,and with a 455,I think even bone stock it will have enough power and tourque to scare ya!
    I saw a 1966 GMC 4x4 at a car show awhile back with a 400 pontiac motor in it--it looked like a factory installation it fit real nice(and it didnt have headers!)--they used pontiac motors in the 55-57 GMC's factory,they also used buick 322 "nailhead" motors in some GMC's back then too!.
  19. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]In all honesty, I'm not sure. Never really looked into them, but mentioned it becouse I've seen the "Kits" in parts catologs like Jeg's, PAW, and Summit in the past. I do remember that you put them together and weld them.
  20. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay I'll look at jegs and summit later. Thanks /forums/images/graemlins/waytogo.gif
