Cheap Link arms
Discussion in 'The Garage' started by miniwally, May 20, 2005.
  1. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,066
    190
    Colorado
    So in my quest to find the lowest cost on link arms I figured out a way to just use some pipe, fire, large hammer and a hand drill to make a very low cost link arms.
    I figure if I take like 2" schedule 80 pipe that I can get for free from job sites. Cut it to length and heat the ends up red hot then smash them with a hammer real good and flat I can then just drill like a 3/4" hole in the flat part and put like a 5/8" bolt through the hole and in to the mounts on the chassis.
    If the mounts on the chassis are the right width the arm can just rotate on the bolt and move around to provide mis alignment.
    What yall think of my idea. I will try to get pics of this this weekend cause I think I am going to do it.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Wow.
    The first thought is that it would be pretty sloppy. The sloppyness would (IMHO) generate poor traction control and it would rattle like all hell. You would also waller out the holes in the pipe or break bolts at the same time.
    But it would be cheap! I think you would be better off with a leaf setup in this case instead of a swingset looking setup.
    You are talking suspension right?
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    would wear and fatigue the bolts as well.
  4. miniwally
    Aug 11, 2003
    3,066
    190
    Colorado
    yes I mean suspension link arms
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't think you need the drill, use the torch to cut the hole, that way it's flame hardened.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Lets run with this for fun.
    If you could weld some spacing on each side of the flattened bar to make it a few inches thick or something and then get a bushing around the bolts so there is some cushion, you might be onto something!
  7. miniwally
    Aug 11, 2003
    3,066
    190
    Colorado
    I guess I could run like some grade nine bolts from the tractor store or something.
    Do you think that a larger bolt would work better. I don't want to drill to big a hole in the end and loose all the strength of the schedule 80 pipe.
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
  9. miniwally
    Aug 11, 2003
    3,066
    190
    Colorado
    Sand man I find what you are saying very offensive and would like for you to edit your post so the rest of the people don't read that kinda dribble on this board.
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Me deepest apologies.
    May your cost sensitive linking discussion continue on.
  11. miniwally
    Aug 11, 2003
    3,066
    190
    Colorado
    Thank you. I am sure everyone appritiates you doing that but no one more than me.
  12. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Actually I think that you could wrap some bailing wire around those connections to get them to stop rattling. I think that and a little chewing gum would really hold up well. Also, there's no need to actually weld anything, JB weld would definitely hold up well for your application. Best of luck, make sure and post pics when you're done.
  13. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't think we would kid around about something as ground breaking as this new idea. Frankly I'm a little miffed at my brother for letting the cat out of the bag before I could patent the idea and incorporate it into a suspension kit. Miniwally, no beer for you! And I'm hiding the Jack too. Wow, that's almost haiku.
  14. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I think large + sleeved pipe could be used... but I think the flattening of ends/bolts idea probably couldn't be made to work. Is there a reason for doing this other than saving $ on heims or cartridge joints?
    j
  15. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It's all about the cheap. Could you imagine? These arms could be almost free! If you were good with a torch you could even slot the holes a little so that it would arcilate better.
  16. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    You could...but then you'd have to rig up some sort of anti-wrap bar. Maybe you could score some re-bar at the job site. That'd do an excellent job.
  17. miniwally
    Aug 11, 2003
    3,066
    190
    Colorado
    We will have a job going on that will be using like #8 bar or larger.
    Why would I need anti wrap bars. I realize that there will be a little slop in the ends but that probably will only be a high speeds. I don't think I will ever take the buggy over like 90 to 100 MPH. I would think that little amount of slop would be fine at those speeds.
  18. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You'd have to get re-bar really hot to make it flat enough to work, I think we better stick to pipe.
  19. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Good point, but you could just use a really long piece of all-thread and jb weld nuts on the axle and a crossmember, that way it'd be adjustable.
  20. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Hey, you could use the re-bar and just weld a pair of washers on it with the mount sandwiched between them. It would work just like a ford radius arm mount except better because you don't have that pesky bushing binding up your suspension. You could even stack the re-bar up to make it stronger so you won't bend them as easy. Of course that would use up twice as much re-bar that could be use on some other part of the vehicle.
    Think of the rotational ability of this kind of mount! This could be way better.
    Hope this doesn't give away any secrets, I think this is an idea I could really use. I've probably said too much already.
