Cheap Little Gear Indicator Needle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefcake83, Sep 24, 2000.
  1. beefcake83
    beefcake83 1/2 ton status
    Jun 24, 2000
    240
    Alaska
    Anyone replace one of these recently and happen to still have the part number available. The orange needle that lets you know what gear you're in and the spring that attaches to the column? Need one and NAPA and Schucks don't carry. Thanks!
    Gary Graham
    '83 GMC Jimmy 350 'Beefcake'
    Eielson AFB, Alaska
    Metallica & Mountain Dew
  2. 82K5
    82K5 1/2 ton status
    191
    kansas city
    hey, you're in luck. actually i have no idea. i broke mine off about a year ago while trying to adjust it cause it was off a gear. it would read "N" when it was in "D". actually i don't even need it. i know where my gears are at, even with OD. you'll get used to it, just like you know where your gears are at when you have a stick shift. after awhile you won't even look.
    o.k. i felt bad about your situation so i just spent 20 minutes looking through my GM parts books. here's the deal. the orange needle and the springs didn't come by themselves, they came in a little package called a transmission indicator dial assembly cover. it's a little cluster that has all the letters for your gears and the housing with the needle and the springs. here's the part number. 469336. the parts group is 4.000-transmission/brakes. the group in that group for the cluster is 4.020. the price is listed at .68 cents. i assume that's actual cost, not what they will actually charge you. you might not be able to get one from GM so a junkyard will probabably be where you will find it. i have a pic of the part, here's where you can find it.
    http://home.earthlink.net/~philmo1/cluster.jpg
    hope that helps.
    Phil in K.C.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  4. Heath-La. 89GMC
    Heath-La. 89GMC 1/2 ton status
    Feb 18, 2000
    134
    Monroe, Louisiana
    I think if you ever fix your steering column, that thing will be screwed up. I fixed the wobbley ass tilt wheel on mine last week and the only thing that i couldnt get back in place was that little orange indicator. I had parts left over after this project and if the only thing thats not gonna work is the orange needle, ill be very happy. I dont need it either. Its an automatic.... its either in forward, neutral, or reverse.
