cheap long slip drive shaft
Discussion in 'The Garage' started by clstolten, Nov 3, 2006.
  1. clstolten
    clstolten 1/2 ton status
    Sep 4, 2002
    356
    So I pulled a drive shaft from a K20 longbed at the junkyard today. It was the type with the carrier bearing. There is 7.5" of splines on this thing. Is this the best I can do without going custom$$$$$$$. It was only $17 and after I remove about 1" of the tube, it will be the perfect length.
  2. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Nice.
    I need a band saw so I can cut tubes level and fab my own driveshafts.
  3. clstolten
    Sep 4, 2002
    356
    I have never shortened a drive shaft but it was easy enough to remove the one end. I don't have a band saw, just a chop saw. The end for the tube is a tight fit and has about an inch insertion depth??? This shaft is for the front and won't see high speeds so I'm not too concerned.
  4. OrangeCrushK10
    Jan 25, 2003
    1,425
    Better than me. I just have a torch and my hand is nowhere near steady enough to make a perfectly straight cut.
  5. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    same setup I was running rear. Just pop off the fixed section of shaft and the carrier bearing and shorten to fit. I am gonna see if a dodge cummins 1350 CV will fit into the tube for a long slip junkyard CV.
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    cut the shaft...
    I've used a large pipe cutter to cut driveshafts down in length--maybe butcher,but it worked fine for me!..I've also just used a bench grinder to "erase" the weld where its welded to the yoke,and then you can just tap off the yoke with a hammer,if your just swapping a yoke..
    I bring my driveshafts to a machine shop though,if its on a street driven truck --I had a home brewed rear shaft in my 72 Chevelle wagon that sat on a 69 Suburban 4x4 chassis,and it vibrated quite a bit at certain speeds..if its just a plow truck front shaft or something,then I'll attempt to do it myself..:crazy:
  7. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    Thats exactly what I have in the front of my 71 blazer with 52's
    Works great.
  8. goldwing2000
    goldwing2000 Guest
    Wouldn't that have been a C20? A 4x4 wouldn't have a two-piece shaft, would it?
  9. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well you can find them in 4x4 crew cabs at least. I haven't seen a K20 with one though.
  10. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    My brother just bought a K-30 dually regcab, longbed, rolling chassis and it has a two piece rear shaft
  11. clstolten
    Sep 4, 2002
    356
    It had a dana 44 8 lug up front. It was a "camper special".
  12. rhino105amx
    rhino105amx 1/2 ton status
    Sep 13, 2002
    159
    Mesa, Arizona
    My 78 Burb with a 4 speed/205 had a two piece driveshaft with a carrier bearing.
  13. goldwing2000
    goldwing2000 Guest
    That's longer than a k-20 pickup, isn't it?
  14. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    Pardon the newbee question but, what section of the driveshaft is pictured and what ujoints would fit? I plan on a 52" spring swap and this may be the answer to the driveshaft length problem.
  15. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    It's the section with the long slip, and would take 1350 joints.
  16. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    I have a 79 K20 with a 2 piece sitting in the driveway, my last also had a 2 piece.
  17. clstolten
    Sep 4, 2002
    356
    RedBrute,
    The section in the picture is from the t case to the carrier bearing. The yoke with the internal splines was attached to the second shaft going to the rear axle. The shaft has 1350 sized yokes. I used a 1350 to 1310 yoke to go to the front axle(d44), and a 1350 to S44 to go to the custom flange I made from the stock CV. No more CV for me, but the modified flange allows for high operating angles. The combo joints are a little pricey. About $30 each at Napa.
  18. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    I have found that a pipe cutter is the best tool for cutting drivelines straight and true. I usually clean off all the dirt and grime and then have at it. The cut is perpendicular to the centerline of the shaft and is already a little beveled for excellent welding.
  19. RedBrute
    Sep 22, 2002
    346
    Thanks for the info. I thought combo joints would be required...the kicker is I went to the J/Y yesterday. Had I known this I'd be hackin' a shaft right now!
  20. garlicbreath
    May 17, 2003
    1,136
    Denver
    I just bought mine new from a local heavy truck sriveshaft shop. I think it was 60 and he turned it down to fit my current shaft.
