cheap mod and free mod (14ff shave and install drain hole)
Discussion in 'The Garage' started by BranndonC, Aug 22, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    http://www.branndoncoelho.com/jimmy/14ffshave/
    i shaved my rear, and installed a hole to drain the fluids a little easier, i also installed one on my front d60. they work great, i counter sunk them so if i get a little rock rash, i can still un screw them /forums/images/graemlins/thumb.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Looks good Branndon, but will the diff leak with those bottom holes cut in half (or am I seeing thing?)
    Looks like you used a sawzall?
  3. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
  4. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Looks good I want to shave my 14 B also.
    Does the drain leak at all?
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    oooh ic. Awesome /forums/images/graemlins/thumb.gif
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    not yet.... havent filled it
  7. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    looks good branndon /forums/images/graemlins/thumb.gif
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    cool! looks good /forums/images/graemlins/waytogo.gif I'm planning a drain (with magnet) in the cover I built.
  9. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Couple of observations (take them for what they're worth):
    1) Don't put a tap in a drill...okay, the guys on American Chopper do, but that's not the way to do it.
    2) Ease up on the loctite...a little dot goes a long way.
    Anyway, nice shave-job...gotta love cheap/free mods.
  10. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I was just going to comment on your generous use of LocTite.
    A little dab will do ya.
    If your worried about leaks with the drain hole use a little plumbers tape and wrap the thrreads with that stuff.That will keep things from leaking.
    You might have to use a breaker bar and poss. a little heat to get that drain plug out now! /forums/images/graemlins/rotfl.gif
    Nice shave job though dooooode /forums/images/graemlins/thumb.gif
  11. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Cool, but... I can't help it...
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you're tapping out a hole that you're going to use for a drain, why not use a pipe thread tap and eliminate potential leaks before they start?
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    What prevents you from threading the plug in too far?
    Why did you shave the top of the differential instead of the bottom? Does that make the plut a fill plug? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  14. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i know thats a ton of loctite, it just all came out at once, i didnt mean to /forums/images/graemlins/blush.gif o well. and i guess the ring gear prevents it from going in to far if i chose to screw it in that far, right now though it doesnt hit anything on the inside
  15. heavy4x4
    Aug 28, 2002
    3,270
    That is (or at least should be) a 1/8" pipe plug. The tapped hole and plug is tapered so it only goes in a given distance and then stops.
  16. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    Looks good. Here is the diff cover I made out of 3/8 plate completely and put a drain in it. Installed it tonight. Will trim diff then trim the cover as needed too.
  17. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Nice job on the shave. /forums/images/graemlins/thumb.gif
    The drain hole... /forums/images/graemlins/tongue.gif
    You used the right amount of lock tite.
    I would clean it real good and epoxy over it.
    Gear lube drippin out a lil 3/8" hole is gonna take alot longer than just poppin the cover off, cleaning the mating surfaces and gluing it back on.
    And now you are gonna have to heat the case to get the set screw out.
    And since it is on the bottom and the case is full of fluid that acts as a heat sink.... stripped out set screw, busted allen wrench....
    It only holds a couple of quarts anyways.
    3/8 pipe plugs are bad enough to get out of a diff when it is buggered.
    A handy tip for the next time you are tappin a hole in a critical area is to smear grease in the flutes of the tap to catch the cuttings.
    I use an air ratchet 3/8 or 1/4" depending on the tap to chase threads but always twist em in by hand to start new threads.
    Broken taps suck big time.
    Then when ya break off the handy dandy tap extracter in the tap....
  18. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    oooh bye bye drain plug, mr rock is gonna love you. No offense but did you mean to cut the "iron cross" that way?
