Cheap Power Steering Cooler!
Discussion in 'The Garage' started by HarryH3, Aug 2, 2005.
  1. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Very nice!
    Kris
  3. 6.2LTrailblazer84
    6.2LTrailblazer84 1/2 ton status
    Jul 4, 2005
    201
    san diego
    That's awsome. Very inventive! :)
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Great tip Harry!
    Rene
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    its too bad caddy dident make a 4x4 with all the stuff we rob off them it would have been great!!!
  6. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Cheap Cooler
    Could probably be used as an engine oil cooler as well.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The tube is only about 1/4-inch. The tube on engine oil coolers are usually more like 1/2-inch. I wouldn't trust it to flow enough volume as an engine oil cooler.
  8. LongIslander26
    Jun 25, 2005
    256
    Hard to tell in the picture.
    OK, it's hard to tell how big the lines are in the pic, but Dammit! I'm going to cool something if it kills me! :rolleyes: :crazy: :D
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Probably a serious requirement in Arizona! :eek1:
  10. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    I has a suburban that had a powersteering cooler stock mounted on the front side of the cross member. That one looks like it would work better though.
  11. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    Thanks Harry. Anymore info, fitting sizes, other makes, ect...
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That's the only car I've found them on. The fittings take standard sized power steering return hose. :cool1:
    I just wander around junkyards looking at every vehicle there, to see what might work for other things. :rolleyes:
    If you need even more cooling capacity, check out the factory trans coolers that Ford used on lots of pickups and vans in the 80's. They're a 4x12 version of the stacked plate cooler, with compression fittings. :D I think they're kinda small for a trans cooler, but might make a nice power steering cooler for those running rams.
  13. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I parted out a C/k series chevy C&C dually and it had a PS cooler mounted vertically on the side of the grill as well.
  14. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Nice tip. Thanks.
  15. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    Fords have them too!
    I've seen similar ones on GM trucks factory,as well as ford pickups too...I wonder if a few feet of copper tubing wound into a spring shape would be just as effective??...
    I know of one guy(our plumber) who was tired of freezing in his truck--I told him to put baseboard heating panels from a house in his Step Van for more heat in the winter!-(we used them in our ice racer cars on the dash for "defrosters"and heat!)---he said it worked so well,he had to put shut off valves in the hoses so he would not get TOO hot!--I bet a few feet of those mounted in the airflow outside the truck would dissapate a lot of engine heat! :thinking: :crazy:
  16. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Check out the Aux cooler used on late 80's Ford trucks. Stacked plate design that is just a little bit bigger. Have one on the Sub for the PS system.
  17. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    nice find, I know where I'll be going the weekend :D
  18. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
  19. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    my burb had one as well, but it was just 2 passes of steel tube run on the underside of the core support, no fins.
  20. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Nice find,thanks...:thinking:
