Cheap rear lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Judd, Sep 28, 2002.
  1. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I was wondering if anyone here has lifted the back by re-positioning the rear spring hangers lower on the frame. I was looking at it and kinda figured I could drop it by at least 2-3 inches or so. I'm thinking about dropping both the front and the rear shackle mounts.
    Also, how beneficial would moving the mounts rearward about 3-6 inches or so be-as far as getting a better departure angle. I'm also running a FF14 bolt rear, 208 t.case and a 700R so my drive shaft agle ain't all that great. Am I running off on a tangent, should I go with a shackle flip or maybe the Ford spring thingie? I'm planning right now, so any input would be appreciated. I'm looking at running 38-40 inch tires with minimal lift as I can get away with. I'm thinking 2-3 inch body lift, a sawzal and the smallest spring lift to get it to work. What do ya'll think my best set-up would be?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    6" lift using ORD 4" shackle flip and 2" lift springs in rear. Along with the body lift and finder trimming should clear the tires you mentioned. I have a 6" lift and am planning on the 4" ORD shackle flip and 2.5" springs this spring to get rid of the blocks I'm currently using. I'd also like to add a 2" body lift and some 39.5s
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    very good Q's, i am wanting to find out similar info also, i was thinking about some kind of hanger/shackle extensions of some kind, i need to carefully study my chassis in the near future and use a tape measure and guage too, hmm
    im staying tuned to this thread.
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I'd recommend a shackle flip. I wouldn't try to relocate anything.
  5. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Rather than go this way; a cheap, effective shackle flip can be had by cutting the front spring hangers off of the rear of a donor truck, then moving these to the rear of yours (after you remove your rear hanger). This provides roughly 4" of lift, and is cheeeeeaaaap. Ask pureinsanity about this, he is doing this mod.
    If you want to relocate something, move your rear mount back a few inches (4), and run the ford 57" rear spring with an aggresive (rearward) shackle angle. I am sure some of the suspension experts may weigh in on this for theory and function, but I know this works, and pretty well.
  6. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Man, this is a great site. Didn't have a computer back when I wheelin in my Jeep. Would have been great to have all the ideas on stuff back then.
    Any more opinions? /forums/images/icons/grin.gif
