Cheap Rock Lights
Discussion in 'The Garage' started by Hossbaby50, Jun 16, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need some suggestions on what and where to get some cheap lights to use as rocklights. I need something that has a built in mount.
    What is the best place to mount the lights? How many do I need?
    I went to AutoZone tonight and got some of there $10 special and they suck. Want something decent quality for a good price. Thanks
    Harley
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hope fully sombody can help you with p/n's but im pretty shure it is at napa, you get tractor lights(crome spotlights) and than there is a part number fro a small plane landing light's blub that will fit in them, my uncle did it 350,000 candle power for 29 dollars pretty cool but i forgot all the details, sorry,
    dale
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    How much room you got ? I used to have the 50 buck 6 " round chrome Autozone lights , worked just as bright as KC's ( they live on c'moe's truck now ). I have the small 5 " square Ralley generic ones on the bumper now, they are bright too. Not as bling as KC's HID's or anything else but for 25-50 bucks they rock. /forums/images/graemlins/k5.gif
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not really looking for really powerfull lights. I am looks for small lights. Like 2" round, 2x3" rectangle, stuff light that. These lights are going to be in the undercarriage of the truck so you can see what is under you and where your tires are at night.
    I have a set of 6" ProComp 130 watt lights for my truck but that is WAY to bright for night time rock crawiling. When you are rock crawling at night you want to be about to see what your truck is doing but not blind the spotter or the rig infront of you.
    Harley
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    oh well just use the stock blub in the tractor lights
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm thinking of getting some 12V flourescents. Nice white light without a lot of glare. I've already got several small, metal housing 55W lights I got on clearance for $20 a pair. Been setting out there in the shop for about 2 years and just never got around to mounting them. Check places like Big Lots, they have these "driving" and "cornering" lights on cheap quite a bit. HF has the square plastic 55W for less than $8 on sale once in a while.
  7. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Just a quick question but if I remember from last summer folks were mountin the lights in wheel wells and what not. Why? This is what my mind comes up with at times so bear with me. /forums/images/graemlins/whistling.gif
    Why not mount lights on magnets up out of harms way off the fenders? They can shine down and illuminate the surroundin ground and can still be moveable if they look like they'll be in harms way.
    Like most of my ideas this is prolly dumb and there is a reason why but just a thought. /forums/images/graemlins/dunno.gif
    Ko now it's time for you to laugh. /forums/images/graemlins/rolleyes.gif
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    A fair amount of lights are self grounding. So you must have them mounted to metal so they have a ground.
    They mount them in there wheel wells to see there tires for tire placement. I am going to have one light per wheel well and probably 2 more under the truck so you can see axles, driveshafts, etc.
  9. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I looked for a long time for rock lights and never found what I really wanted so as usual the do it yourselfer in me took over. I decided to get what I really wanted I would have to build them.
    So what I did was procure some aluminum, 1/4" thick plexiglass, The plexiglass is different stuff. We used to bend it on a steel break at work and it didn't crack. Anywho, I tigged the housing and found some small halogen bulbs to go inside. Screwed them in and ran the wires through a small hole in the housing. Sealed it all up and stuck in a couple thread serts which will get rubber washers around them to seal up plus some silicone. Nice part about these is when they mount to the frame they cast light in a 45 degree angle down and out. Works out nicely and not glaring bright. Anyway here's a shot or two of them.
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am using 4 of those small rectangular "driving lights" They are the goofey yellow looking ones the ricers put under the plastic front end. The yellow light is kinda different to get used to but it is doable. They are rated at 55W and I got them for $20 a pair at HF. I also had a set of fog lights for a while and those worked okay. One inside each fender is plenty for me. The rectangle pattern casts ligh real nice and wide.
  11. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I imagine your getting the same kind of light dispersal that I am. Mine shine straight down from the frame and out about 10 feet or so. I had never thought about using those small ricer lights. That's cool somebody has to put those kind of accessories to good use!
  12. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    You get a generic tractor light like a 4" round housing at the parts store we worked it it was Petersons brand and they were plastic hosuings with a mounting stud. I then popped a aircraft light in it, 4309 ? i think(i'll double check) they have a rating of 100,000 candle power.
    total $50 for 4 lights
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    sylvania bulb 4509
  14. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Wal-mart carriers tractor lights. They are under $10 and they have a rubber housing. I think they are 55w lights. Can't really remember though. Maybe it is time to take anouther trip to Wal-mart.
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I picked up 2 Tractor lights at Napa today I am going to wire in in a few minutes. Hopefully they will be bright.
    $10 each, rubber armor casing. they are GE lights.
    Harley
  16. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I got some little 55w halogen lights and bolted them to my hitch. My buddy put them in his boat. They are oval shaped so he used a hole saw and filed out the oval. Once the light was fitted he used some silicone to hold them in and I cut and rebent the mounting brackets to hold them in from the back side.
