cheap spare tire mounting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by audacious, Apr 13, 2004.
  1. audacious
    audacious Registered Member
    Mar 10, 2003
    34
    tx, austin
    looking into getting rid of the inside spare tire mount, and mounting the tire on the outside in front of the tailgate. is it worth a try? i have looked all over and found nothing less than 300$ for a blazer built one that comes off the bumper. thought about taking a bronco mount and modifying it to work on my blazer. been done before? anything i might need to cut or reinforce? i have glanced at the bronco setup and it looks to connect in two places on the right side back corner, locks on a slant in the middle of the tailgate, and seems to have some inner plates to help reinforce the corners.id like to get more room in the back and looks like it'll work; so what do u think?
    thx /forums/images/graemlins/thinking.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think you'll have to weld in some metal to help spread out the weight on the body
  3. audacious
    Mar 10, 2003
    34
    tx, austin
    ya i was thinking of makeing inside supports for the arm mounts on the corners. to bring the stress off the body. maybe large bolted plating on the inside or bumper supported arm for the middle? i still need to take a good look at the way it is supported on the bronco.
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    You might need to beef the body supports more than normal if you're going to be carrying a 33" or larger spare. It's suprising how that little bit of extra weight can reshape the body panel mounting points. I picked up a rear bumper with a mounted swing-out carrier and it works great.
  5. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Valley equipment used to make one just for the blazers. This is what GM used(i think) when somebody wanted 1 from the "factory". They bolt on to the 1/4 panel and have plates that go inside. There is also another bracket that bolts to the gate. Easy 2 hr install. Although they don't make this product anymore, I have found them used on this site. I have bought 2 so far. They work good for stock tires, But I would be worried about anything larger than a 33 on an aluminum rim!! I put 1 on my 87 and after a bit, I noticed the bottom of the 1/4 panel was pulling out. If the floor wasn't so rotted out, I would have made a brace to hold the 1/4 in place!! but thats the only truck that I had a weight issue with.
    Place an add in the "parts wanted" section. and keep your eye's in the "for sale" area.
    This is the tire carrier on my old 76.(recently sold, boohoo!!)
  6. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    There are two flavours of that Valley Industries-style ... I think Hickey sold them Back In The Day, too, though I donno if Valley made them for everybody.
    Anyway, there's the one bablazer73's pic shows, and there's a longer one (goes further to the left) to hold a gas can.
    If you're using a big tire (i.e. bigger than stock) try and stick with the shorter one, or at least don't hang the forty or so pounds of gas can on it -- the longer lever and greater weight will yank on your qurter panel something fierce.
    -- A
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have been thinking of getting one from a Jeep catalogue. Slides into receiver hitch and holds spare tire. Could probably make one with some square tubing and make it hinged with a second pin on vertical part so you can lay it down . Just thoughts /forums/images/graemlins/k5.gif
  8. audacious
    Mar 10, 2003
    34
    tx, austin
    well evryone thanks for the ideas. i looked up the bronco idea and found that it would be a pain to do(too many modification). so im just gonna fab my own with the help of some welding friends. they said it would cost less and be alot stronger. im getting alot of the stuff (hangers and hub mount) from a local trailor dealer. thx again
  9. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I installed a Bronco style tire carrier on my '84 Blazer. I had to add spacers for the top mount and the latch mechanism. I just bolted it on all the way through the corner post. It has held fine for 3 years now with a 31" tire and steel wheel. It has been leaned on and swung all the way open against the stop and I haven't had any problems. It is great for a cheap tire carrier. I do plan to make my own bumper mounted carrier in the future.
  10. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    You want cheap? Buy a 4 tie down bundle and some duct tape /forums/images/graemlins/waytogo.gif
  11. 82 silverado 4x
    82 silverado 4x Newbie
    Apr 4, 2004
    4
    East of Pittsburgh,Pa.
    Blazer Chalet's had front bumper mounting carriers if you don't care which end of the truck you want to mount it.
  12. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    bought a rear bumper from Kennesaw Mtn with spare tire carrier. saw it hear in ck5. It's a heavy duty piece of equipment. should hold any thing forever. but they are slow. dont be in a hurry
