Cheap Turbo upgrades
Discussion in '1982-Present GM Diesel' started by rennyd, Jul 20, 2004.
  1. rennyd
    rennyd Registered Member
    Jul 20, 2004
    10
    Hi folks I'm new to this site and new to GM Diesels. I will have one hopefully this weekend if all goes well. 84 Suburban 2500 auto 6.2l Diesel NA 4x4 3.73s stock height. I was wondering if it is possible to do a junkyard turbo upgrade. I come from the world of turbo volvos where you can make a 13 sec grocery getter for under a grand. Probably not as cheaply done here but I was wondering if that is possible here to? If so what trucks year/modle should I be looking to nab parts off of and what parts. I already have a TO4E off or a D9 Cat that I was going to use for a v6 project volvo.
    Also how does the injector pump get adjusted to add more fuel? Sorry this has probably been asked a 100 times but I couldn't find it when I searched.
    Renny
  2. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,036
    1,095
    Dallas
    Every good running 6.2L deserves a turbo. Banks is the only company that I know of still offering a compelete kit.
    However:
    All that you really need from the Banks kit is the exhaust manifold and crossover pipe. Pick your turbo from there just as long as it has a straight exit like a TE06H or a T04E.
    The Banks airbox is pretty, but it's not necessary as one can fab an intake easily using pipe and a cone filter. The plenum is neat as well, but a superior piece can be hand made at a fraction of the price.
    Wrapping the crossover pipe keeps heat energy inside the exhaust before the turbo, and that decreases lag and helps overall efficiency.
    If I had it to do over again, I would go with the Banks exhaust, manifold, crossover pipe, turbo oil feed/drain, but fab the rest myself. That cuts a few hunderd dollars of the price tag, and in my opinion one would end up with a better setup.
    The Banks kit is a perfect option for someone that just wants basic turbo power, but isn't terribly interested in tuning past that.
    As for which turbo, I like my TE06H, but will probably end up using a 60-1 T04E with a .68 a/r ratio and P trim wheel. Garret and Master Power make some of these turbos. Anything with a T3 flange will bolt up.
    Adjusting the fuel rate:
    Before tearing into the injection pump, make sure you've got clean hands and the area around the pump is clean as well; something as small as a piece of lint can clog an injector. With the cap of the pump removed and the diesel fuel drained from the bowl, look down through the sight window for the adjustment screw. We've found that it's not necessary to remove any of the pump linkage to access the sight. Using a 5/32" Allen wrench, turn the adjusting screw to alter the fuel rate. To increase, turn clockwise; to decrease, turn counter-clockwise. We chose to use a brand new t-handle wrench since the adjustment screw turns tight, and if stripped, then it's a bad day. Banks recommended a 1/4 turn increase, so that's where we chose to start. Depending on your DB2's plunger size and RPM, different adjustments may work better.
    Some pics:
    http://www.oliverdiesel.com/images/6.2TD/banksturbo/db2capoffdieselcleared.JPG
    http://www.oliverdiesel.com/images/6.2TD/banksturbo/adjustingfuelrate.JPG
    /forums/images/graemlins/thumb.gif
  3. rennyd
    Jul 20, 2004
    10
    I read in another post some one talking about parts off of the 6.5 turbo - is that possible and has any one done that?
    Also on the adjustment I am looking at the pics of the pump, thanks for those, and I don't see the Allen screw or sight - where is it in relation to the shaft that comes across the pump? Please let me know.
    Renny
  4. AgDieseler
    Jan 25, 2001
    1,036
    1,095
    Dallas
    6.5 turbo parts will fit a 6.2L, but don't clear the AC housing well at all. If you have a truck that doesn't have AC, or you feel comfortable removing it, then I recommend using 6.5 parts all the way. Otherwise, a Banks exhaust manifold for the appropriate year is your best bet IMO.
    The screw can't be seen in the picture, but get that far down, and you'll see the sight window. You must rotate the engine BY HAND to get the metering screw to appear. It's not tough to find with a good drop light.
    /forums/images/graemlins/cool.gif
