cheap way to lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88jimmyoungowner, Nov 23, 2001.
  1. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    i am 16 , and i have an 88 jimmy that is mostly stock. I want to get it lifted to fit some bigger tires under the rig, but i dont think that i can afford a $2000 lift. should i go all body lift, or should i get a combonation body lift and suspensio lift, and what kinds of lift should i get? I wish to get 33x12.50 tires on it.
  2. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    only cost like 800 for a 4 inch bds with all you need including new front and rear spring, shocks, and steering arm, or you can get a 4 inch from rough coutry for like 259
    hola
  3. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    oh yeah i also had 32's under my blazer before my lift so you might even able to trow some 33's wth no lift or even a 2 in suspention lift
    hola
  4. 88jimmyoungowner
    Nov 20, 2001
    425
    georgia-rome
    i hit the fender with the 31x10.50's i have now with the stock suspension, so i dont think that i can get away with that.
  5. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    just get a 4 inch bds they ride so nice compared to stock springs and you prolly need to replace the shocks any ways and those come in the kit hey and if you can fill out your profile
    hola
  6. 88jimmyoungowner
    Nov 20, 2001
    425
    georgia-rome
    sorry, but i am young, stupid, uneducated.....bds?
    16, 88 jimmy, give me advise if i ask for it, please!!!!!!!!!!!
  7. GONZO2
    GONZO2 1/2 ton status
    Jul 17, 2001
    137
    formerly Great Falls, MT now Lompoc, Ca
    you hit the fenders with 31" tires? [​IMG]
    my 85 with saggy springs never rubbed my 32's with max flex and i had running boards too.
    anyway it don't cost that much to lift these k5 trucks. most 2-4" systems are in the $400-$600 range. if your springs are sagging as bad as it sounds then i would go for the systems that get new springs all around.
    the cost is the labor to install, if you can't do it yourself. new springs are not hard to install, just a pia due to bolts that have been on for years.
    <font color=blue>85 blazer</font color=blue>
    <font color=blue>88 blazer</font color=blue>
    <font color=blue>99 30th ann. TA</font color=blue>
    <font color=blue>79 TA</font color=blue>
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    BDS stands for "Big Dicks Suspension". No, seriously, it does! [​IMG]
    From what others have experienced and I have read, they are possibly the best lift springs on the market today due to the best ride characteristics and the best warranty, which cannot be beat by anybody else.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  9. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Go with a 4" lift and get some 35's. Cheap and easy to do.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  10. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    big dicks..........suspesion that is, hey i'm only 16 too, <a target="_blank" href=http://www.bds-suspension.com/>bds</a>
    hola
  11. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I'm 17 and I bought a 1990 GMC 1/2 ton pickup, and I lifted it 3" with spring blocks and 3" with body (and an icky 3" torsion bar crank that sucks balls) and I've gotta put in my $.02. DON'T body lift. It rattles, eats up cab mounts and is an overall pain. For the 90 bucks your gonna spend for a body lift that has everything you need, you might as well save up another couple hundred bucks and get full springs all arround, you'll be more satisfied with it and it'll last longer. If you wanna cut some cash you could put in a 1" add-a-leaf in the back with 3" blocks and 4" lift front springs. That may be more economical and take the sag out of the blazer's rear-end.
  12. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    hmmmm I had 305's which are equivalent to 33's on my suburban, stock and I didnt rub, even flying off the highway off ramp??? wonder how bad your suspension is if your rubbin with 31's??????
    --Brandy
    IF ONLY THE 4 YEAR OLD COULD TURN A WRENCH
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear 12 bolt dana 44 front, TIRED ol 305-
  13. Grim-Reaper
    7,385
    Atlanta
    I can scrub all 4 tires with a 4 inch lift and 32's. [​IMG]
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  14. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the cheapest way to lift is to buy a lifted truck.
  15. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I rub a ton when i flex alot, so i got to cut our my fenders
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. Locked front and back.
  16. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Find yourself an inexpensive 4" front spring lift (new or used) from someone like Rancho which has 4" lift blocks. Throw out the lift blocks and cut your rear shackle hangers out from the bottom for a homemade 4" lift shackle flip. The compression style ride is great and the price is about as cheap as you'll get for a 4" lift. I bought a set of 2" blocks which I'm gradually tapering to get the right pinion angle and combat a set of stock saggy rear springs. It sits about 1" higher in the back now but looks level and rides very good. I hammered on those shackles pretty hard in the desert on Thanksgiving and they did better than expected, a good compromise untill the rest of the truck comes together.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  17. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    I have 33's on my 83 with facotry suspension and have yet to rub.
    Ryan
    Never knock on DEATH's door. Ring the bell and run...he hates that!!!!
  18. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Try removing the sway bar. You'll flex much better, and prolly rub like hell with 33's.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
