Cheap winches?
Discussion in 'The Garage' started by k5freak44, Oct 10, 2004.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I dont think those will last very long.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    seen a guy with the 8000 on a toyota, boy was it slow. thats all i know
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    1.6hp motor compared to a 6hp motor on a warn winch.
  5. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    At least get a milemarker
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its better than nothing, but not worth it im my opinion. i remember that the 8000 took about 5 minutes to pull him 30 foot.
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    A couple of friend of mine have them. Bought like they and have no bad reports. They are slow, but hey, they work and are cheap! Not bad for $299... I think they're made by Chicago Electric.
  8. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    get one of those new tmax winches, designed in aussieland, made in china... they are supposed to be decent.
    j
  9. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    The HF winch ratings are misleading. If you look at the instruction manual for the 9K winch you will see it is really only 4.5K with single line and 9K only with a snatch block on double line. I think the 8K winch is really 4K unless using a double line pull although the manual no longer states that.
    HMMM
    Jeff /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
  10. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    829
    Pinckney, MI
    Just wait awhile then get a warn!
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    They are almost the same exact thing as the milemarker electric sieries and ramsey REP series. They are not fast (said many times before) they heat up easily (due to lots of spins from the tiny motor) and are truly meant for intermitent (sp) use. That being said we have on of the HF on a multi mount, and I have the cheap ramsey (REP 8.5) bolted to my K5. They work but I wouldn't want to pull more than 10 ft with one. I am a rocks only guy so 10 ft is about as far as I usually have to winch.
  12. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    If you have a PTO output on your transfer case or gearbox ( I do not what you have) you could find a deal on a used HD PTO winch. My buddy runs one, and it is seriously strong. Check the heavy equipment yards or your Edison company boneyard. They can be had for cheap, and are available up to at least 20K pound rating. /forums/images/graemlins/yikes.gif
  13. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    good call... PTO winches freakin rock! you may think you're rig is stuck, but with 20-30,000 lbs pulling on it... its either comin out or yanking off your recovery point. /forums/images/graemlins/tongue.gif
    j
  14. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The HF winch looks just like the MM but they are alot different if you compare specs.I got my MM 8000 from 4WPW for $317+ tax with free shipping.
    Its not fast but it is better than nothing.Im way happy with it.
  15. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    They are good trailer winches.
  16. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I just got my E12000 Milemarker winch a few days ago and it looks nice. It's got beefy 3/8" cable and came with a mounting plate, roller fairlead and cover. I wont have it mounted until spring because I'm lacking a job, but I'll let you know how/if it pulls my 44's out of waist deep mud. /forums/images/graemlins/waytogo.gif
  17. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    There is a 3 way comparison (raymart vs ramsey vs superwinch) in the new issue of the JP rag. All three of these winches are a step up from the HF and MM but the bottom end for price of a supposed reliable winch. It is a quick read so just thumb through it at the store next time you are there.
  18. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I have a cheep harbor freight one hooked up to my trailer as far as I am concerned that would be the only thing it's good for, it is extremely slow but it works well.
