Cheaper to Buy or Fix?
Discussion in 'The Garage' started by Jeremy_C, Dec 26, 2003.
  1. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    I've got a stock front axle on my 79 4x4. It needs the following things, per a garage i trust.
    Both Rear Axle bearings@Seals (rear)
    Inner and outer Wheel bearings@ Seals(Front)
    Both Front axle joints
    All three front driveshaft Ujoints
    1 set screw for rear spider gear pin.
    Sounds like BIG money, but if i fix it, i wont have to worry about having to do the same stuff to a different axle, just wanted your thoughts on this. /forums/images/graemlins/thumb.gif
  2. James670X
    James670X 1/2 ton status
    Nov 15, 2002
    122
    Calgary, Alberta, Canada
    My suggestion would be to just rebuild it yourself, then you know what's been done and what hasn't and you'll save yourself from being ripped off in the long run because it's very easy for some clowns out there to tell you it's been rebuilt when it hasn't or for some shop to hose you.
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Actually none of that stuff is too terribly hard to do yourself with the proper tools.
    If you trust the shop then the parts probably do need to be replaced, and if you can't or don't want to do it yourself then I'd say have it done by them. Unless a D60 is in the near future. Even then I wouldn't let the bearings and seals go for too long or else you won't be able to drive at all! I'm sure you know all this so I'd just go for it! /forums/images/graemlins/thumb.gif
    It really shouldn't be that expensive unless they jack up the price of parts too high, in which case I say bring in your own bearings, seals and u-joints and tell them thats what you want put in. Most shops I've delt with don't mind this too much, as long as your cool about it and don't try to look like your getting over on them.
    Then all you have to worry about it the cost of labor, and that shouldn't be too bad for the work your asking for.
    Hope that helps
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    sound sliek easy fixes to me, just bearings and U joints and a screw? that all could be fixed in about two hours tops if youre good /forums/images/graemlins/laugh.gif
    have you checked on prices for those parts yet ? they cant be too much price /forums/images/graemlins/laugh.gif
    good luck
  5. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    Me not good /forums/images/graemlins/pimp1.gif lol
  6. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    Im sure some one from this board would be willing to give you a hand.
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Where do you live? This is all very easy work with the right tools like said above. I have every tool needed to do almost any repair you could ask about.
  8. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    I'm in Tennessee, when i get some bills squared away i'm gonna drop it at a garage an let them have at it. I dont use my truck as a daily driver anymore, I have a county owned car i use. /forums/images/graemlins/thumb.gif
