cheapest or different alternative for insualtion in a pole barn
Discussion in 'The Lounge' started by bad_bo_ti, Jan 30, 2005.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    what is the cheapest, or a different alternative for insulation in my polebarn. i dont have a lot of money but can peice and part it together as i get the money. thanks, chris
  2. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Straw bales
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Hay (straw) bale insulation... good insulation, but thickness steal alot of space. stylafoam sheets, is what I use so you could do it as you go and it's easy to cut & install.
  4. Storm Trooper
    Nov 24, 2000
    4,640
    I used 2" Blue board in mine but it does cost some $$$.
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i you can save up the coin get is sprayed with foam.
    and if you useing it as a shop i would recomend aganst hay bails man that place woud BURN
  6. bad_bo_ti
    1,027
    OhiO
    strawbales thats funny. i am using it as shop and will probably not drywall or plywood or whatever over the insulation till later on. has anybody used the radiant barrier that is kinda like foil? i thought about going this route since it would be flamable and would help reflect light lowes or homedepot has a 4x125 foot section for 62 bucks. i would have about $186 going this route just for the side walls.
  7. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    I am the supervisor for simonson Insulation crew been insulating for about 4 years and I will tell you dont scrimp on insulation the more the better the more you spend now means less youll be spending later (heating) the spray in foam is the best out there now, in some cases it will increase strength in the building up to 75% !! Thats a huge number but it cost is alot
    what is your studs at 2' 16''on center? get me dimensions and pitch and I can run the numbers and get you a general on what all the diferent insulations should cost:)
  8. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    if not finished off you might want somesort of fire proof stuff also.
  9. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    You could always stack the hay bales outside the building.
    What would your neighbors think if they saw you pulling in and out of a giant haystack.
  10. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    BOND FIRE!!:yikes: :yikes:
  11. bad_bo_ti
    1,027
    OhiO
    i guess that is one way i could heat it too!!!! if it gets to cold like a bale on fire :weld:
  12. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    "Bond, James.... JESUS CHRIST I'M ON FIRE!"
    A bale on fire.... cold?
    Spelling Police Sub Unit of U7 OUT
