Cheapest place to get a real high lift?
Discussion in 'The Garage' started by sled_dog, Apr 9, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    My burb is spending the night in the woods. Think if I had a high lift it wouldn't be. So whats the cheapest place to get a high lift jack? I don't want to deal with 4 Wheel Parts.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    around $39 for a 48" at Blains Farm & Fleet in south east Wi. is the cheapest i have seen. Other than E-Bay
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Do you have a farm store near you? Fleet Farm and Tractor Supply Company both usually have them for around $43 for the all cast ones.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    TSC has them for $47 here for the 48" model
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I paid $55 for a 60" all cast at the local farm store. They had to order it though since they only stock up to 48 inchers.
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    You all mention the cast version of the hi-lift. What would the other be, forged? I take it frged would be better? probably more $$?
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    No, the all cast version is the good one, it's the version that's red. The cast/stamped version is the other one. A little cheaper, a few of the parts are stamped instead of cast. They're painted black. I've never seen a cast/stamped jack fail but the all cast version is usually only $5-$10 more (correct me if I'm wrong)
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the all cast jack and the cast and stamped jack. the all cast lasts longer but cost a little more.
  9. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Thanks for answering my hijack, fellas.
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    FWIW, I wouldn't bother with the 48"er. Get the 60"er.
  11. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    Make sure you get the 60"
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I got a 48" for my Burb. Stock height truck it worked great. I will be ordering a 60" whenever I get near finishing the project truck.
    By the way I went to Tractor Supply and it was only $27 for a nice all cast one. it wasn't a high lift but it worked great.
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I take it you got it out then? Lift it and tip the jack over or use it as a winch?
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    neither. Lifted with the jack in the back, stacked rocks under the tires. Did the same in the front and I just drove right out. Look for my thread from yesterday called "stuck". Has a picture of it after I put rocks under the tires and before I drove out, also some nasty flex pictures(nasty cause my body disconnected quite a bit)
  15. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I got mine 48"er from a pawn shop for $15. A spray of WD40 and it works great.
    I'm wishing I would have got a 60", but at the time 48 was more than adequate.
