cheapest place to get drop pitman arm for crossover
Discussion in 'The Garage' started by cegusman, Mar 13, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Where is the cheapest place someone has found the ford 4" drip pitman arm? The cheapest I have found was $80, I know I read a thread that you can get them for $40 where would that be?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I cant remember for sure, but I think I bought mine from either Summit or 4WPW for about $45
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Mine was $40 plus tax at 4wpw. I just got it last week, so I know that they should still have them for that price. </font>
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    This $40 pitman, what taper does it have? 1/2 ton or 1 ton?
    How much measured drop does it have? (from very TOP of arm, to TOP of dropped side being the measurement)
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's the Superlift 1104 arm that everyone on here gets... </font>
  6. Waxer
    1,857
    Long Beach, CA.
    Ok from a writeup I found, that arm is tapered for the 1/2 ton ends.
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
  8. Waxer
    1,857
    Long Beach, CA.
    Actually he said it has the same taper is the ORD arm. Nothing was said about it being 1 ton vs 1/2 ton.
    I went to a writeup on off-road.com/chevy where Shawn Spickler uses the Superlift 1104 arm and some 1/2 ton ends. That is enough for me to figure out that its tapered for 1/2 ton.
    Here's the writeup ----&gt; Off-road.com Writeup
  9. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    All TRE's are tapered the same the difference is in TRE's and DLE's Taper is the same on them, but the diameter is different.
    $40.00 is a screaming deal on that arm $45.00 is about the norm.
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Well that's nice. Looks like I'm f**cked since I didn't read well enough. Now I need to try to find a damn shop around here that can retaper the thing. I got a Rockstomper drag link with the one ton ends. Dammit... /forums/images/graemlins/angryfire.gif </font>
  11. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Does superlift make another arm like the 1104, but with a bigger drop?
  12. Waxer
    1,857
    Long Beach, CA.
    Butch, you are correct sir. When I had my other pitman arm in the machine shop, the tapered reamer that they used fit both the existing tapered hole before and after they were done. Same degree taper, just reamed out a bit more for the larger ends.
    I just wish this reamer was a bit less expensive to get.
  13. Waxer
    1,857
    Long Beach, CA.
    You have 2 choices. Replace the 1 DLE with a TRE and be done with it, or you can find a machine shop to ream out the hole for you a bit. It costed me $40 to have that done once before.
  14. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'll have to check on the price of the DLE, if it doesn't cost too much then I'll just do that and keep the TRE that I got from Rockstomper for a spare. I swear, if it isn't one thing it's another... /forums/images/graemlins/rolleyes.gif </font>
  15. Waxer
    1,857
    Long Beach, CA.
    You had it right the first time /forums/images/graemlins/smile.gif
    The TRE will be around 20 bucks. Not a bad comprimise. It is what I would do in that situation until I came across a deal on a good reaming out of the taper on your pitman.
  16. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, now I'm a bit confused. ROckstomper apparantly likes to put TREs on everything, including their drag links. I got a DLE for the steering arm side of my drag link since the Shanker arm is tapered for a DLE. The other end I assume is going to come with a TRE on it. So I need to replace that with a DLE, since that is what the superlift arm is tapered for. Do I have this right now? I'm sure that it will become apparant when I open the box up but we might as well clear this up on this thread for the archives... /forums/images/graemlins/thumb.gif
  17. Waxer
    1,857
    Long Beach, CA.
    The TRE = the smaller taper
    the DLE = the larger taper
    It does get confusing a bit.
    The Superlift arm is tapered for GM TRE (smaller of the two). If your draglink comes with a TRE, then you will already be set.
  18. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, it looks like I'm good to go then. My Rockstomper stuff came in and the big long ugly old DRE end fits the steering arm, and the TRE is in the other end of the drag link so that should fit the superlift arm. It looks like the DL might have a little too much drop in it but we shall see, I assume that Rockstomper knows WTF they're doing. /forums/images/graemlins/crazy.gif </font>
  19. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Hey just swing ov er to the 4wpw by the astrodome and buy the SUperlift #1104. They didn't have it in stock but shipped it from the Dallas store and it was on my doorstep THE NEXT DAY /forums/images/graemlins/thumb.gif I told them to give me a 10% discount since I'm a ck5 member and showed them my card and they gave it to me. I think my total price with tax was $42 and change.
    -- Mike
  20. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Anyone know how much drop these arms (1104) have? Thanks
    -fLeXy K20
