Cheapie 14BFF gear swap
Discussion in 'The Garage' started by KevinsK5, Jun 23, 2006.
  1. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    I am looking for a K20 14 bolt to do a bolt-in swap on my Jimmy, haven't located one with 4.10's and an open carrier. I do have a dually 14 bolt with 4.10's and an open carrier which is exactly what I want, just wrong housing. Suppose I find a junkyard K20 rear with 3.73's and a gov loc. What are the chances of pinion bearing preload, pinion depth, backlash, and carrier bearing preload being dead on by just bolting it all together in the K20 housing exactly the same way it came out of the dually housing? Thanks, Kevin
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I would say between 10% and 90%. Really I have no idea but in my searchings its actually hard to find a 14b ff with 3.73s almost all I have seen are 4.10s as far as the carrier you could change that no problem
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Others will chime in soon, but thats what all the adjustments are for is to compensate for differences between one housing to the next. Pinion depth is the big driver. These were designed before CNC, so the shimming operations were needed to compensate for eyeball precision.
    So even if you didn't have to make adjustments, you'd still have to check.
    On second thought, you do have to perform the drill. The carrier assembly will either fall out or won't go, and pinion has to have the correct preload or its sloppy or tight.
    A "mini" shim kit should do it.:D
  4. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    Thats what I thought. I just don't have a dial indicator so thats why I asked. Went junkyard shopping today and found a 14 bolt with 4.10's, buuuut, popped the cover and it has a gov loc (three spiders visible from the outside of the carrier right?) I'm gonna pick it up for $140, and I guess I'll either weld the gov loc or try dropping my open carrier in instead. Thanks, Kevin
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Um why dont you just move the spring perches? or is this a c&c axle?
  6. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    Yeah it's a C&C, it's too narrow, and the shock mounts are on opposite sides of my Blazer. I'm thinkin its worth it to buy one out of a K20 to save the headache. :dunno: Kevin
  7. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Dial indicator is cheap at Harbor Freight :deal:
    -- A
