Cheapish inch-pounds torque wrench?
Discussion in 'The Tool Shed' started by dremu, Jan 23, 2007.
  1. dremu
    Feb 27, 2000
    15,963
    452
    East of San Francisco
    Any recommends on an inexpensive, occasional-use baby torque wrench, like 20-50in-lbs full scale?
    Harbor Freight doesn't seem to have any, which is okay as their stuff can be TOO cheap ... Sears sells a KD Tools for ~$50 (found it elsewhere online for ~$40) ... anything else?
    -- A
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    For what purpose are you wanting one? There are several different types of torque wrenches and a purpose for each type. There is a clicker type, dial type and a bar type.
    FWIW, i've bought all of mine from E-bay and they are all snap-on and i got them cheap. Couple of them were brand new and others were slightly used. You can always have them calibrated after you buy them. I would not skimp on buying a cheap torque wrench though. Buy a good one or don't buy one at all.
  3. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    yeah, there really isnt a point to buying a cheap torque wrench, you want something that is quality and calibrated from the start, ive heard of kd and HF/northern versions being up to 25% off.... out of the box...
  4. dremu
    Feb 27, 2000
    15,963
    452
    Well, I have a nice click-type 1/2" drive for doing the Real Stuff, but a little beam type one would be good for, say, checking drag on 14BFF pinions :D
    That's why I said "cheapish", as I too firmly believe that a cheap tool is worse than no tool at all. Just can't justify a ton of money in this instance.
    Thanks!
    -- A
  5. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    i have a KD 0-50 in/lb beam type, if your going to use it for pinion preload, you'll want something that goes lower than 20
  6. dremu
    Feb 27, 2000
    15,963
    452
    Yeah, so Scott told me in a PM. 20-25 top scale max.
    More searchin'... thanks all!
    -- A
  7. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    maybe mine quits at 25..... been a while since i used it. i do know it goes down to 0....
  8. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    They are $300+, but a Snap-on Techwrench allows you to adjust range, from NM, to FT-LB, to IN-LB, and adjust digitally. They also don't need to be "unwound" after each use. They are expensive, but they are very easy to use and save lots of time. Worth a look from anyone who uses a torque wrench frequently.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Here's one I have bookmarked, but it's 1/4-inch drive. You'll need a stack of adapters to get it to fit a socket big enough for a 14 bolt FF pinion nut. :(
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    An inch pound torque wrench that goes from 0-25 will be a 1/4" drive and will require a couple adapters.
    The dial type would be best for checking pinion bearing preload.
  11. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    X2. That KD2955+two CalVan Tool push/pull adapters+crapsman 1/2>3/4 adapter. The CalVan is sold at Sears also.
    I measure preload both CW & CCW and split the diff.
  12. dremu
    Feb 27, 2000
    15,963
    452
    As I said, I have a perfectly good 20-150 ft/lb clicker that's served me well thus far.
    -- A
  13. dremu
    Feb 27, 2000
    15,963
    452
    Adapters, no problem. I expect that. Dial type, check. (But I saw you using that beam type :bow: )
    -- A
  14. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I used the beam type at work because my dial type is in my tool box here at home.
  15. dremu
    Feb 27, 2000
    15,963
    452
    Hey, no arguments -- it worked for you :)
    Other than a few random Ebay hits, though, I'm having trouble finding either style in such a small scale ... fortunately I won't be doing my other 14BFF for some time, i.e. until I regear... but it's still irritating :)
    -- A
  16. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I've been keeping an eye out on e-bay for you as well. I'll let you know if and when i find one.
  17. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Go to a bike shop they will have the beam benders in a small scale for pretty cheap if they sell tools
  18. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I have a dial-type, 0-30 inch pound range, 1/4" drive. It was around $70 and is made by CDI Torque Products Model #301LDIN. I'll see if I can dig up the link where I bought it.
    EDIT: WOW, everywhere I find it online, it's twice as much as what I paid, or more! Yikes. It's a good wrench though, comes with a calibration cert. and a nice foam lined blow-molded case.
