Cheater Bearings and bearing pullers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Jun 3, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Ok in the new 4wheeler they have a geae swap article, and mention "cheater Bearings" for setting up the pattern. Sounds like a good idea to me but how much do they cost? I can't think of any practical way to bore a regular bearing and really am doubting they are common except from the source them mentioned
    The bearing puller they showed in the pic also looks like it would save me some time....looks easy enough to build but what exactly does the bearing hook on to. I see a adjusting bolt in the side. Is there a bearing splitter inside?
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I'm still waiting for my issue :-(
    What I have done in the past was buy a pinion bearing and have at it with a carbide burr and die-grinder then it was easy to get the depth figured out with out destroying the bearing every time you have to make an adjustment.
    See ya
    my truck's not dirty, it's earth tone paint
  3. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    Any machinist, worth his salt can do it to a standard bearing. He'll chuck it up in a lathe and use a radial grinder. He'll change it from a interference(press) fit to a slip fit. Get a set of carrier bearings done along with the inner pinion race. Of coarse, all this depends on which axle your working on! This is mostly for Danas. Corporate 14BFF do not need the "cheater" bearings. GM really had their head together when they designed this Baby! I believe the 10 Bolts have the shims outside the bearings, so no need there!
    PS I'm not a machinist, I had a set done!
    Good luck,
    Ron
  4. Cavalry
    Oct 1, 2000
    978
    I'll have to mention that to out machinist....He was probably thinking of getting some that night or something when I asked him....
    Luke
    84 K5
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    You'll still need the cheater bearings for the pinion gear setup. You can do these at home. Get an extra set of bearings for the setup your doing. Take those bearings adn clamp them down in a vise. Get a cylinder honing tool, put in on your drill and hone it out. Or you can use a round file and just file away till it slides on. The bearings are about 11 bones each.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
