check engine light came on
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by surpip, Nov 10, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    while i was goin down the freeway in OD, when i got to my exit, i shut it off and started it again, and it turend off and diddent come on again all the way to work........Any ideas? It has done it before, (when i first got it)and it would loose alot of power, so i changed the oil and filter and the air filter, and it diddent happen any more. This time when it did it it diddent lose any power at all /forums/images/graemlins/dunno.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    pull a code and tell what code it is.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Here.s a link on how to check codes:http://www.troublecodes.net/GM/
    Your ALDL connector is on the bottom of the dash under the steering wheel.
    Find out what code its throwing and post it.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya but the light isent on any more will the code still be there? dumb ass me i should know this crap
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yes. Anytime the CEL comes on the problem code is stored in the ECMs memory for aprox 50 starts.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    right on ill try to check it this weekend i dont have the time during the week, ill problally get it Thurs Night
    thanks alot,
    dale
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    What year is it? What kind of car?
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    89 blazer, my truck
  9. rescuekrawler
    rescuekrawler Registered Member
    Nov 7, 2004
    28
    dealer have the scan tool and it only like 10$ to do it!
  10. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Most autoparts stores will do it for free. Or a paper clip in the A/B terminals will give you the code too.
  11. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Likely an O2 sensor. When they start to go bad, they respond slower. The first place the computer regcognizes that slow repsonse is constant rpm driving on the highway.
  12. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Jump the 2 pins in th eupper right corner, with the key on.
  13. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Ignition module going bad???? The truck would still run, but with a lot less power.... /forums/images/graemlins/dunno.gif
  14. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    mine throws an EGR code every now and again, whenever I run the interstate at constant speed, just like once a week or so.
