Check Engine light on, doesn't send out codes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RockyRider13, Jan 22, 2002.
  1. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
    Check Engine light on, doesn\'t send out codes
    when i am driving for a while, and the temp gets up to around 210, the check engine light comes on in my 89. It doesn't always come on though, and when it does i can faintly smell gas (my imagination?). Anyways, the code scanner doesn't tell me jack when i check it with the engin off, it only spits out "12" any ideas??
    Be a simple, a real simple man
    -Lynyrd Skynyrd
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Re: Check Engine light on, doesn\'t send out codes
    Maybe try throwing a lower temp. thermostat and see if the lower temperature fixes it...does it only come on when the temp hits 210 or does it come on at lower temps?
    Chris
    Was that a speed bump? No, just a Rice Rocket </font color=red> <a target="_blank" href=http://coloradok5.com/gallery/fortcollinsram>My 87 Blazer</a>
  3. RockyRider13
    Jul 11, 2001
    102
    Kansas
    MOST of the time, but it does come on at slightly lower temps sometimes (about 20 degrees lower, but never right after start-up while the engine is still cold)
    -Lynyrd Skynyrd
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    my 88 did that for a while, id drive for a good distance and the truck would get good and warm and it would come on. the exhaust smelled real rich after it came on too. at first it wouldnt spit codes but after it did it for a while it spit out the code(32 i think) for the EGR valve. i changed that and havent had the problem since.
    Might be worth a shot.
    Later
    Have you driven OVER a Ford lately?
