Check engine light question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Jul 29, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I am now wiring up the Check Engine Light but I have a question. Does the check engine light wire from the ECM emit the ground or the power? I looked at the wiring diagrams and it shows that the check engine light wire also runs to the "D" pin in the ALDL plug. What I was thinking is if some could check the plug for me.
    Thanks,
    Charles
  2. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    ground., for an 88 should be the same for yours, i am sure because i'm wiring in the check engine light to the lt-1 ones computer, but do to other things being more important at the moment i haven't actually soldered it in so every time the bare wire hits the bare dash my chek engine light comes on.. /forums/images/icons/shocked.gif
  3. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    88streetblaze,
    When you say bare wire do you mean the ECM wire or the LIGHT wire?
  4. 88streetblaze
    Jun 27, 2001
    314
    it's the wire that is an output from the ecm. right now it is not hooked to the ecm, just the light, and when it grounds out the light comes on. on the 88's the wire does not actually go the the aldl plug itself, there is a 6 plug connector that has most of the aldl wires, but it actually goes the the i/p., i haven't looked at my schematics for the 85/6 that closely, so it could very well be different.
  5. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Thanks for the help and info. I'm sure the ecm wire is the ground because if the bare wire on the light grounds the light comes on. If the the ecm wire was the power and its not hooked up then that wouldnt happed. Right?
    thanks,
    Charles
  6. 88streetblaze
    Jun 27, 2001
    314
    you've got it.
    you would think they would specify that stuff in the wiring diagrams.
