Check Engine Light
Discussion in 'The Garage' started by BlazerWheels, Dec 19, 2004.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    Comes on after about 15-20 minutes of Freeway Driving. Does not happen at low speeds, only after extended driving of 65 an over. The vacuum to the EGR is unplugged (and capped), would this make it think there is a problem of some sorts??? Truck runs fine, just the light decides it wants to shine. Any help is appreciated....
    How come I can't find the smileys?????
  2. dyeager535
    26,975
    Pull the trouble code with a paperclip (instructions all over the net on how to do this with GM OBD1 systems) and see what the ECM thinks the problem is.
    It very well could be EGR issue. I'm not sure what happens with it unplugged. Seems to be one of those items that is "sometimes" an issue when it's not working right.
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I had the exact same problem. The code I got was a lean condition. I replaced my sticking EGR and 2 years later the light has not come on again. Why did you plug the EGR hose?
  4. BlazerWheels
    Feb 13, 2003
    587
    California
    I had an issue of hesitation (more like stopping) from a dead stop, mechanic plugged it just to see if it was the EGR leaning out the mix. When he plugged it, the hesitation went away. Need to put on a new one, and have not yet, so I left it plugged.....
