check engine light
Discussion in 'The Garage' started by dunehopper502, Aug 18, 2005.
  1. dunehopper502
    dunehopper502 Registered Member
    Mar 1, 2004
    56
    MI, U.S.A.
    my 90 k5 blazer keeps setting a code 42, light will intermittenly go on and off tried to clear by disconnecting battery but came back on....
    any suggestions on where to start diagnosing? alls i know so far is it is an est issue for my timing....i have msd distributor,6a box,msd coil and msd wires
    thanks
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    my 87 kept setting the esc code...i found the knock sensor wire pinched under the starter...just a thought
    ryan
  3. dyeager535
    26,979
    I believe others have had the code 42 problem, losing the MSD solved it.
    Not saying you need to pull it, just keep that in mind while trying to figure it out.
  4. dunehopper502
    Mar 1, 2004
    56
    MI, U.S.A.
    well ive had msd for a couple of months now and this just started,could it still possibly be the problem, i was told my pcm was bad from the vibration of the boggers
  5. dyeager535
    26,979
    People love to blame what they don't understand. ECMs are almost never bad.
    Dunno what causes code 42 in TBI trucks, but heres the TBI code 42 test procedures out of a Camaro manual. Let me know if wire colors are the same. :)
    Code 42
    BTW, pulling the ECM fuse is a lot better than pulling the battery cable. Contrary to what most say, 10 seconds seems to be more than enough time to clear the ECM codes.
  6. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    i killed my 6al box in 6 months from bias tires even on the supplyed mounts. got warrentyed and upgraded to offroad box . no more problems.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Code 42 is pretty common trouble code with 6al boxes. Also the MSD distributor modules are not as good as AC delco. The module may be throwing the 42. Try bypassing the box and hooking up like stock to see if that works. If you still get a 42 the pickup coil or the module are probabally going out.
    If the 42 goes away after disconnecting the box you found your trouble.
  8. dunehopper502
    Mar 1, 2004
    56
    MI, U.S.A.
    awesome guys thanks for the great info, give me something to do this weekend after the woodward cruise of course......
