Check Out My Bumpers
Discussion in 'The Garage' started by Kg6kjs, Jan 9, 2007.
  1. Kg6kjs
    Kg6kjs Registered Member
    Nov 18, 2006
    33
    Glendora, Ca
    I am working on bumpers for my Blazer. For a couple of reasons. 1. To fill the 3 inch gap from the body lift. 2. So I can have recieve mounts front and rear. I am not finish as you can see. Both bumpers with have 2 shackle mounts each. They are made from 7ga cold rolled steel. I am still making the mounts. I made a little rig that holds the heavy bumper in place while I make the mounts. I will update pics when I complete more. I just wanted to get some feedback and opinions. From you guys.
    The holes in the rear bumper are cut out for 5x7 Pro Comp Lights. This bumper will recieve 2 shackles like the front. Both pins for the recieves are located on the back side of the bumpers. So I have to reach underneath to put pins in. That way they don't stick like 4 inches out. The bumper is just resting on the dimond plate. It has nothing to do with the bumper.
    I started with plate then scored the metal where I wanted the bends then bent it over and welded it.
    I ended up welding every seem the whole way then grinding it all smooth
  2. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    Nice work!
  3. Kg6kjs
    Nov 18, 2006
    33
    Glendora, Ca
    Thank You, These have taken me along time about 18 hours already alot of grinding and welding. This is the first time I have tried to make my own stuff. I couldn't find what I wanted forsale so I was forced to start making my own.
  4. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    I'd say it looks DAMN good for you're first shot at fabricating!! Very Well Done! It looks like you took your time in the planning and layout before you even touched any metal with anything. Bravo! I wish I had my crap together that well. :rolleyes:
    Later,
    Buddy
  5. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Looks great man....BEEFY!
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Wow really awsome job!
  7. HoodRich
    HoodRich 1/2 ton status
    Jul 30, 2006
    160
    Kernersville, NC
    Looks good, reminds me of a road armor style bumper.
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    X 11teen!
    Unitl I read all the way down I figured you'd had a shop make up the bent pieces & then welded them together. That's what I did for Patch's front. That's an exceptionally good job on the lay-out.
  9. cjjones
    cjjones 1/2 ton status
    Feb 20, 2006
    111
    To the north
    Those are GREAT!! Nice job.
  10. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    Holy crap thats sweet! wanna sell some cutout sheets for that? how'd you figure out where to score it all the first time?
  11. BSav
    BSav Registered Member
    Nov 4, 2002
    41
    South East N.H. USA
    bumpers
    wow they look great. how did you score the plate before you bent it?
    Brian
  12. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    nice work, not my style but very nice bumpers. good job on layout.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    personally, i think they're ugly. send them to me, and i'll make sure they're properly disposed of. :D
    how bad was it to come up with the design? might be interesting to try for my '93.
  14. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    very sweet man!
  15. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    Man, that is some inspiring work your doing there. I expected to be many peices all welded together. Did you do a mock up in cadboard or something, and then just use it as a stencil??
    I like the design, very clean!!
  16. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    those are awesome man. how did you do that so good the first time.
  17. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,004
    605
    Pueblo, CO
    Ditto on the design and fab work. Looks sweet. I'd be up for a copy of the layout too. I'd love to build a bumper that looks like that!
  18. Kg6kjs
    Nov 18, 2006
    33
    Glendora, Ca
    Well, I first built the bumpers out of cardboard the cut the cardboard out so it was all one piece. I then layed it on the sheet metal painted the edges white as seen in one of the photos. then cut out that shape. To get the points were I wanted to bend I checked the bends in the template compy then to the plate with a sharpie. Then I used a grinder to score the lines. I score the lines till I was able to bend the metal. I then welded in the gap that opened up when I bent it over. I do like the look of the Road Armor bumpers on newer trucks. Mine should come out good ounce they are finished and have the shackles on them. I will be able to reciever mount my wnch front or rear. I will make myself some matching rock sliders also. I will post more pics as I do the work.
  19. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Very Nice! I really like the bumper holder upper thingy. I would not have thought of that, just used some jack stands and blocks.:rolleyes: What would you guess they each weigh?
  20. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Those look great. Very nice work.
