Check out my fender trimming idea
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Dec 4, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Click here for some pictures of last weekend's fender trimming results. I cut a pretty good amount out, and I kept the wheel well... I cut notches along the edges and bent back the segments to make them flush. Soon Im going to fill in the slits with some filler and then undercoat the entire well. Should look clean.
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    That looks really good--looks like you took your time and did a great job /forums/images/graemlins/thumb.gif Be sure and post pics when you fill in the slits and do the undercoating would like to see the finished inner fenderwell. Keep up the great work /forums/images/graemlins/pimp1.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    /forums/images/graemlins/cool.gif
  4. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    That's exactly what I was thinking about doing since I have rust in the upper part of all of the wheel wells. Looks cool.
  5. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    I don't need to, but you make me want to trim my fenders /forums/images/graemlins/thumb.gif Can't wit to see more pics..
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I did something similar to run my 35" with 2.5" lift, but now I am removing the whole front sheet metal, going with an engine cover and some home made flares to keep it legal and run 40" with the same lift.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Looks nice!
    So you're going to fill the cuts in the inner fenderwell with body filler? I don't think that's going to hold up for very long, it's probably goig to fall out in chinks pretty quickly. Body filler isn't really intended to fill gaps like that. If you want to make it look nice I'd suggest either welding the cuts up or fiberglassing it. </font color>
  8. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Ill only fill in the gaps for the notches that I made on the wheel well layer... the inner fender layer above that I think Im best off just leaving alone. Ill post pics as soon as I get some time to get working on the truck again.
  9. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    What is this engine cover you speak of? Is it home made or does somone make it. I hacked my fenders some more and removed my inner fenders to fit the 42's, so now I'm lookin for a way to shield my engine when things get wet.
  10. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Tack weld it together, remove the entire thing and get some brazing rod and braze it up. The body filler won't last long.
    If that's too much like work go get some urethane for windshields and use that with a putty knife. You can make it look almost as good as body filler and it'll flex instead of crack and fall out. I use urethane all over the place. It doesn't paint for [censored]. Plasti-kote bedliner sticks to it though.
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah it's going to be home made.
    I am building a cage around the engine and fabbing a cover with aluminum sheeting, and fasteners.
  12. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  13. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
    Looks good but it looks like your tires are still going to hit in on the lower portions of the fender. You probably didnt need to cut any off of the top of the fender, tire usually doesnt hit there unless you have a ton of flex.
