check out the detail on this one
Discussion in 'The Garage' started by bajaviking, Sep 4, 2006.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    holy crap, i wonder how many hundreds of feet of filler rod they used to build that chassis
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    With all of those wash welds I'd guess there's 75+ lbs of filler in that chassis.
  4. bajaviking
    Apr 10, 2002
    752
    Baja
    When I see pictures like this I begin to understand why these trucks are so expensive to build and I also begin to get a stiffy:D
  5. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    ok noob question here, what is filler rod and why is it used?
  6. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,812
    396
    Clayton Del
    I wonder how long that took to make? It would take me two to three life times to do!!!!
  7. bajaviking
    Apr 10, 2002
    752
    Baja
    Filler rod is a thin steel rod used when Tig welding to add material to the weld.
  8. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    I see, thank you very much. :waytogo:
  9. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    can any of you explain to me how the drive train is set up on that thing..
    it has a rear engine, but the rear ?swing arm? seems to mount to the chassis in the middle if the engine..
  10. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    i especialy like the front shock upper shock mount.
  11. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    home fabricators take notes, there is a wealth of education in these pics for sure. granted we rock crawlers wont be doing 140 through the desert but the quality of your rig and you surviveing a serious crash or roll over, posibily miltiple times depends on how well you build it.
    look at the welds, the stacked coin method you here people decribe is actually a weaker weld unless the overlap of the weld pool (each dab of filler rod) overlaps the previous weld pool by atleast 80 to 90 %. I see welds here on ck5 all the time where the weld is only overlaped by as little as 40 to 60% of the previous weld pool. you end up with this wide/narrow effect which is a weaker weld. you see in these pics their welds are consistantly the same width the entire length of the weld.
    even a mig weld should be this consistancy too. guys that mig weld that do this type of method of welding do the same thing, too big of seperation in the weld pause.
    you also see where everywhere there is a bolt the contact point of the bolt head and nut is double walled to eleminate pull through and add rigidity and strength to the structure. all most all the gussets are of tube rather then a plate type gusset on the center of the tube so in a wreck you wont get a narrow gusset actually punching through a tube. a single plate type gusset only contacting one wall of a given piece of tube is weaker then a tube gusset which uses the full width and structure of a tube.
    some joints have the tube with a bend radius in the tube right at the point of contact of the ajoining tube instead of just a straight line into the ajoining tube with the end coped. this gives a bigger surface area of contact and more weld in the weld joint, hence a stronger joint.
    every bolt is in a double sheer situation not single shear, again much stronger.
    Im not saying build your rig like a trophy truck at all Im just saying look at the pics, there is a lot you can learn from them about structural integrity and design for sure. there is a reason why that truck was built like it was. it was not built like that from day one in racing, there built with this extreme type of construction because they evolved over time and FAILURE and probably some or alot of trial and error to become as reliable and indestructable as they can be considering there intended racing environment.
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    definitely needs more nodes and triangulation. :grin:
    j
  13. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    ssshhhhaaaawingggg
  14. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    RG is a fan of using boat type V-Drive gear boxes. There may now be a purpose built gearbox, but early-on they were all V-Drive boxes. Which is why the diff opening in the housing is so far offset. The V-Drive box lives under the driver's feet (& a little further back if ya kno what I mean :eek1: ).
    A note on those welds; In desert race fab they employ a "wash-weld" technique. What that means is TWO passes. Frequently those passes are two different welders. The high guy on the totem pole does the fitting and the root pass while a low guy does the wash-weld as that takes longer than most fitting & root welding. The root pass is as described above. Then the second pass weaves back and forth over a width of 2X-2.5X the thickness of the base metal. The idea is to widen out the bead & give it a larger radius fillet so that the weld is less of a Stress Riser, and the desert guys think it looks cool.
    I've long speculated that another bonus in using a bent piece of tube for a gusset (like up at the top-outer corner of the windshield) is that the bent is slightly less rigid than a straight piece would be, and that's a good thing. It lets the chassis tweak a little and come back to square rather than forcing permanent deformation. Ideally the chassis would be totally rigid and that wouldn't be needed, but the reality is that if you build in a little flex the chassis will live a lot longer. Bare in mind that these are 4130 structures and unlike a mild steel chassis, those do have a set life span.
