Check out the project....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Oct 12, 2002.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    /forums/images/graemlins/thumb.gif Project Eeyore
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Looking good
  3. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Hell yeah, looking good!
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    sweetness!!!
  5. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
  6. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    How far back did you move the rear axle?
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I see you have to rebuild your big block. That isn't a bad thing in my opinion. Now you can up the compression and get alittle more power out of it. I'd go 9.5 to 1 if you plan on running pump gas. Higher if you wanta buy the really expencive fuels. I know they cost more, but I really like forged pistons !!!!!
  8. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I don't know!! I used a 1 ton frame and rear springs. I turned the springs around(front to back) and that was good for about 3-4 inches. Other wise I just mounted the spring as far back as I could. I will measure the wheel base today and get back to you.
  9. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    /forums/images/graemlins/frown.gifYa, I pulled the heads off and it HAS to be bored. I was hoping to just hone the and replace the rings. The manual says a max of .005 of ware. I have about .015 in the cylinder and a hole in the #8 piston. The speedo says 46,000. I figured about 146,000. After pulling the heads, I think 246,000!! What is funny is that the inside of the motor is really clean. Very little carbon build up. /forums/images/graemlins/thumb.gif
  10. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Cool project.Lots of cool ideas.The only thing I see that ya may want to add is some sort of stop on the rear shackles to keep them from inverting after being fully extended.My buddy has a shackle setup like that on the front of his Toy and sometimes they flip the wrong way after being fully extened.
  11. sapper
    Jul 11, 2001
    3,052
    NoVa
    I'm glad you pointed that out i didnt even see the shackle, looks like a good idea almost revolver like
  12. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I thought about that. If you look I left a little tear drop like peice on the hangers. I have lifted it up with floor jack and as of yet they have not over extened, but there is a pre cation built in incase they do.
    I have been trying to figure out where to run the snorkle to. I want it inside the cab, but don't want all the noise that will come with that. Any ideas?
