Check out these bad-a$$ high-steer arms!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thatK30guy, Jun 9, 2002.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    Designed and built by Eric Ruehl and Bob Roggy.
    These arms fit the D44 flat-top knuckles and put the tie-rod behind and on top of the front axle. Also incorporates crossover steering, too. /forums/images/icons/cool.gif
    Click to see these bad boy arms. /forums/images/icons/wink.gif
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    Pretty damm nice. /forums/images/icons/tongue.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I even e-mailed Bob Roggy for a price for these arms. /forums/images/icons/tongue.gif
    Are you ready? /forums/images/icons/shocked.gif
    For the 2 large arms and 2 spacers under them...$430.00!!!!!!!!!! /forums/images/icons/tongue.gif
  4. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    bob roggy makes some quality parts...i saw his rig at cal rocs in reno..and there were a few in the competion that he built...very nice stuff /forums/images/icons/grin.gif
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Interesting thing about those arms is that they increase the Ackerman (toe change with steering). It changes from parallel steer (or close to it) to somewere near "classic ackerman" (toe out in steering...reverse ackerman is toe in when steering). This would cause the tires to skid sideways so much at low speeds and might help get rid of some of the "push" at high speeds. Fun stuff to mess with...I wonder if he even knows what he has done?
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    they look awesome but not that awesome for $430 ouch lol
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    wonder what wheelbase it is set up for.
    rear tie rod is the only way I can see to get good ackerman
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That might be strange...with the parallel steer that all the axles I have seen come with it doesn't matter what the wheelbase is when you do axle swaps. Those hi-steer arms might work well on a 100+" wheelbase and suck on a heep. Would be a expensive mistake!
  9. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Unless he stretched the heep to 100"s /forums/images/icons/wink.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I dunno, having some ackerman is better then the negative(wondering if that is correct term) found in stock style.
  11. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I tend to like more ackerman. So IMO these arms are a good thing. It would interesting to drive the same rig before and after to see what change it made.
    As a side note we used ALOT of ackerman on our little autocross car. The outside tire would turn about 30* and the inside tire about 45*. It handels assome (2.4g in the corners) in the tight stuff...and tracks that vette's fit thru it just flys!
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yup i agree with ackerman is good thing.
    usually see it listed as %
  13. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    IIRC it was about 125% ackerman...maybe a bit more. It was adjustable and I'm not sure where we left it.
    0% being parallel steering and 100% being "classic ackerman" (ie where the lines thru the steering arm intersect at the rear diff)
    You might find this interesting (along with some other geeks)
    ackerman.zip
  14. ryanNC
    ryanNC 1/2 ton status
    Dec 7, 2000
    182
    North Carolina, Valdese
    i just hope with the tie rod in the back it doesn't hit the front of the engine on uptravel. it looks like it might hit that pulley or the fan. ...might be catastrofic or i could just be tired.
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    dead link for me
  16. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Hum...what's your email...I'll send it to you.
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
