Check out these hose clamps
Discussion in 'The Garage' started by roadnotca, Dec 20, 2006.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I like those... Now where can I get some of them?
    John
  3. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    There should be a box there to "find a dealer" by zip code.
  4. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    summit sells something like those called Python clamps or something like, spendy, but I do want them
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    hmmm....sounds interesting, anyone have any personal experience with them?
  7. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    :thinking: interesting
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Those are pretty neat. Id like to see how exactly they attach/ tighten
  9. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    We had some installed on coolant lines on my work truck (semi)
    They didn't do so well with the high pressure.
    Maybe it was the installer, but I sure wasn't happy.
  10. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    from what i've heard about them, they are like heat shrink, you heat them to shrink, and the engine heat is constantly heating them.
  11. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    how do you get them off to work on stuff?
  12. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    you have to cut them off
  13. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    These are what I was talking about
  14. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    The literature says "thermoplastic" which means they shrink but they don't harden. Their literature probably also recommends against using them for really high pressure, but then they're designed for "heater hoses and radiator hoses". They have to be cut off with a hot tipped tool like soldering iron or hot knife.
    I came accross these while looking at the AGR site. AGR uses them to attach a fluid reservoir extension (neck) on the power steering pump.
    Give it time, it's a new product. I'm sure we'll find more uses for it, like household plumbing? :haha:
  15. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    while not entirely a bad idea, I still dont have any problem using good ole hose clamps. But who knows maybe some day Ill be saying, "son, back in our day we had these metal bands that went around the hose with a little screw to tighten the hose."
  16. tcoker79
    tcoker79 Registered Member
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    What are those neat little things called?
  17. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Bling Clamps:haha::rolleyes:
  18. aknight_sa
    aknight_sa 1/2 ton status
    Oct 14, 2005
    305
    Saudi Arabia
    this might be a dumb question but why are there some hoses like the AC hoses that use some kind of compressed metal clamps while at other places like fuel hoses metal bands with screws are used??
    is it a matter of pressure??
    thanks
  19. blazinzuk
    Dec 20, 2002
    17,412
    3,799
  20. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Screw clamps on DIY like water and fuel. It's just a small % that work AC. Could be higher pressures too, but crimp clamps are faster and cheaper on the production line. :D
