check out this linked 72
Discussion in 'Center Of Gravity' started by Chris Demartini, Jan 22, 2004.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: check out this liked 72
    Yeah saw that last night, he says it will be 6" shorter but those rear link angles still look waaaay steep! But maybe I'm just jealous that he has all his coils on his shocks and 4 of mine are still on order /forums/images/graemlins/crazy.gif
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I noticed the rear looked a little steep, but its 6" higher right now than it will be and the truck will probably have a fairly high COG when finished. Also, I've noticed those guys like to build a lot of AS into they're rigs.
  4. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    !!! BINGO !!!
    .....looks like quite a bit of anti-dive as well. /forums/images/graemlins/ignore.gif
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Just remember, it's going to settle quite a bit with body and drive train. Those c/os are topped out with no weight...
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Jason, what springs are you looking for? I might have some if you need to borrow them till they come in.
  7. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Some 16" 200-250lb coils for the 2.5 shocks... But mine should be here Tuesday so no big deal... Tenders are coming too.
  8. zcarczar
    Feb 10, 2002
    2,495
    Ah, I dont have any that big anyway.
    What do you guys think the steering will be like on that '72 with a tracbar and panhard rod that are different length be?
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Being at the same angle makes alot more difference than the same length. I am sure it will have less bump steer than stock push-pull or even corssover with leaf springs...but it will still have bump steer.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    BTW, that's a track bar and drag link. AFAIK, pan hard (sp?) is the same as track bar, i.e. lateral axle location. If there is some defining difference, I don't know what it would be...
  11. zcarczar
    Feb 10, 2002
    2,495
    Oops, had a brain fart. I tend to do that a lot. /forums/images/graemlins/rotfl.gif So basically if you want to almost completely minimize bumpsteer you should mount the draglink and trac bar at the same angle and make them the same length, but do they have to be mounted at nearly the same location?
  12. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    For 0 bumpsteer yes they would have to have the ends in the exact same plane. But, this goes out the window when you turn the steering wheel since the draglink will no longer be in the same plane as the tracbar. Or just go full hydro /forums/images/graemlins/grin.gif
