Check out this mount
Discussion in 'Communication (CB | GPS | HAM)' started by Predator, Nov 29, 2001.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    Hey you radio guys, will this mount work good transmitting and receiving. I got a bracket like the military uses for its big mobile antennas, then I mount a swivel ball onto the bracket, then a 5' Firestik antenna. All this would bolt onto the tailgate. Check out the links for my mock-up pics. What do you think?
    <a target="_blank" href=http://www.geocities.com/gettin_deep/cbant.html>http://www.geocities.com/gettin_deep/cbant.html</a><P ID="edit"><FONT class="small">Edited by Predator on 11/30/01 08:11 PM.</FONT></P>
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Link no worky :(
  3. Predator
    Jun 19, 2001
    130
    OKC,OK
    [​IMG] OK here's the link:
  4. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    If you can get the SWR correct it would work fine I think. There are ground issues also and I'm not sure how that ball swivel grounds or doesn't ground. I would take it to the local CB shop and have them check/tune it for you. Truck stops usually do that also if you can't find anywhere to go.
  5. Predator
    Jun 19, 2001
    130
    OKC,OK
    The ball gets grounded by a wire from the body to a ball mount bolt. Don't know how good that is......
    My K5 Buildup: <a target="_blank" href=http://www.geocities.com/gettin_deep>http://www.geocities.com/gettin_deep</a>
  6. Skigirl
    Apr 2, 2001
    2,563
    Why do you want a swivel ball on it?
  7. Predator
    Jun 19, 2001
    130
    OKC,OK
    Well I had originally thought about using a ball so I could loosen it and fold the antenna down across the tailgate and hold the end in a bracket when its not in use. But further trials revealed this won't work cuz it also swivels out when turned. Also, I think the antenna just looks better "necked down" with something before attaching to the larger bracket.
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I would still mount it to the side and up more.I have mine mounted by a ball with a 5' France and my SWR's will not come down below 2.5 I spent three hr's at a cb shop to find out I should of mounted the ball up about 12in so it wouldn't get the interfearance from the body. but if I had mounted my ant. on the tailgate I think it could be a pain when you needed to drop the gate
    just my .02
    Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  9. Predator
    Jun 19, 2001
    130
    OKC,OK
    Wouldn't it have more possibilty of getting ripped off on the side? I was thinking now about the "lift and lay" mounts for boats and such. If that would work, I could still fold it down if I needed to lower the gate. So it needs to be as close to the top of the tub as possible??
  10. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Your right it could get ripped off the side, I don't know if there is a "great spot" to mount the ant. the best place is on the roof but it would get ripped off there as well. I went with the side ball mount mostly because I had a hole in the side when I bought the 83. It's hard to find a place to put an ant. that won't get ripped off by a tree or a rock. And yes if you do mount it on the side go up high on the body. I can't remember just where the Army put those mounts to begin with that would be a good starting place and lastly where did you get that mount? I'd like to see if one would work for me.
    Eric
  11. Predator
    Jun 19, 2001
    130
    OKC,OK
    I believe the Army mounts theirs right behind the doors on the upper part of the tub. I picked up the mount on Ebay.
  12. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    I'll keep me eye out for one here in colorado, I hope that what ever you end up doing will work for you.
    Have a merry merry and a happy happy
    Eric
