Check this deal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, May 31, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I just got off the phone with a salvage yard who said he has a 3/4 ton (he thinks it says k-20 on the side) 78 or 79 lwb 4x4 chevy truck with both axles under. He'll take $400 for the axles and toss in the wheels and tires it has on it. He'd pull the things for me too. So I guess I'm looking at a 10 bolt front and a 14 bolt rear? So is it a safe bet it has 4.10s and not 3.73s? I just want the same gears front and rear so I can keep wheelin this season. I know the rear axle is worth at least half that and if the wheels are decent I could run them while looking for nicer 8 lugs. Whatdoyaguysthink? If I'm able to go tomorrow I'll see about getting the driveshafts to.
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    It should have a Dana 44 and a 14FF. The gears could be either. I bought a complete '78 K20 a while back for $350 and it had 3.73:1 gears. Check and see if it has a turbo 400 with a 203 t-case. That is the perfect start for a doubler. Sounds like a decent score if both axles are in good shape.
  3. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    I think if it's 3.73 I'll pass on the deal. I want to get lower then what I have now (3.73) even if it is a strength upgrade in the rear. I think the quick test to check ratio is turn one wheel one time around and count how many times the drive shaft turns right? If it's a tad bit more then 4, it's 4.11, if it's about 4.5 times then it's 4.56, if it's almost 5 times then it's 4.88. This is the right way right guys?
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Pull the rear cover off and check the ratio stamp on the edge of the ring gear. Inspecting what you buy before handing over the money is not out of line...
    Rene
  5. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    I agree with Rene. I will never buy another axle without pulling the cover. I bought a D44 once that was "in great shape". When I got home(70 miles) and pulled the cover I found several ring gear teeth in the bottom of the housing.
    If you are serious about buying them, then the owner should have no problem with you pulling the covers.
    Mike
