Check this out, poor mans locker video!!
Discussion in 'The Garage' started by 87BrnRsd, Feb 16, 2006.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
  2. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    Now THAT is a kick a$$ idea!!!!!! I would put one in on each side:bow::bow::bow:
  3. Alaska K-5
    Alaska K-5 Registered Member
    Mar 10, 2003
    54
    Alaska
    Seems simple enough....
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    so its just a welded rear with some filler metal?
  5. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Thats a great idea, I wonder why it hasnt been thought of before????:thinking:
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Would something like that cause any vibrations? or is it not enough to worry about. It looks pretty simple. I have a open 60 I wanted to weld now I can do this and remove it easily if I dont like it:D .
    Ira
  7. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Wont come up for me.
  8. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Came up for me. I would ratherso it the old way that I have done them before. It is still removable.
    Ira, I found the box that I kept my spare D60 Spiders in. Next trip down I will bring them. I should be able to have them welded beforehand so all we would have to do is swap them in.
  9. sandawgk5
    Oct 28, 2003
    6,881
    Sweet, I still have my 14FF spiders, side gears and shims if you need them to make a ball out of. Did you get your detroit figured out?
    Ira
  10. readymix
    May 30, 2004
    6,706
    26
    No I never looked at it. I have been way too busy. I have been driving it from Temecula to SD and back every day though. I figured on an average it will cost about $700 in gas per month, add that to the possibility of a costly repair.......WOW.
    I did fix the vent on the transfer case though. Only took about 30 Min.
  11. sandawgk5
    Oct 28, 2003
    6,881
    Ya I still gotta do that to mine also as well. I got those guts if it is a problem you can spool it or run it open.
    Ira
  12. 87BrnRsd
    Apr 21, 2003
    2,457
    I dont know, but it looks like it would work well. It may also be more raliable than just welding the spider gears.:confused:
    -Harrison
  13. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i dont know how well that would work since the gears are conical... they want to come out. i know the strap of metal is there and the gear should bind into place, but binding is also pusing out. i would weld more then he is sugesting. also placing screws into a "thin" casting is asking for cracks i think. balance COULD be an issue but could be lessened by doing it on both sides as well as taking up some force from one gear to two.
    im an overkill guy and love the idea shown, but would want to weld a lot more than sugested. still easier to undo than it is with full welding.
    Grant
  14. n8sjh MI
    n8sjh MI Registered Member
    Apr 10, 2005
    12
    Grand Rapids MI
    I have seen guys weld up rears before by taking small chucks of steel and welding them into the gears. Kind of the same thing as putting the gear in and strapping and welding.
    Also not so big on adding screws into the cast?:eek1:
  15. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    What sort of axle is he using in that demonstration? Clearly it's not a 14BFF....
    I am looking at a set of "takeout" spidergears and crossshaft that sit on my desk as a paperweight...and there is nowhere near the kind of room between the spiders as he has in that video.....certainly not enough for an additional spider to just "drop in" as he demonstrates... :dunno:
  16. sandawgk5
    Oct 28, 2003
    6,881
    Open 10 bolts have that kind of room. I am pretty sure my front 60 has that much room also.
    Ira
  17. readymix
    May 30, 2004
    6,706
    26
    Yeah the 60 does
  18. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    not a 10 bolt though, it's a 3rd member he's working on, maybe a Ford? unit?
    just watched it again, and again, he's using the extra spider gear to lock the other spider gear with the two side gears,,,kinda interesting.:thinking:
  19. goldwing2000
    goldwing2000 Guest
    That should work with just about any axle besides a 14bff (or any other axle with quad spiders, if there are any).
  20. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the ford 9" spiders are fully encased like the 14bff. maybe a toyota rear??
