checked my 10bolt front
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Balou, Apr 17, 2000.
  1. Balou
    Balou 1/2 ton status
    Apr 15, 2000
    207
    back to Germany
    found 1" oily rubber tube fixed to the diffs top!
    found another 2" fixed to the fraime right under the servo, cutted both ends.
    What is it for, does it belong together?!?
    Balou
  2. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    These are breather tubes. You should have them on both dif's, x-fer case, and trans. Make sure you have a breather on the top to keep water out. Jim.
    BigJBear '80 GMC
  3. BB454
    BB454 1/2 ton status
    Apr 2, 2000
    134
    Gauteng South Africa
    Thats your breather for the diff. The tube/pipe allows your diff to adjust the pressure inside itself depending on the temp. of the oil inside. Yes the tube should at least long enough not to suck in water (if you do wade the truck into water) Your rear diff should have one too - the same applies there. Good to check your auto. trans. while your'e at it. Very few people know that the automatic trans. has a simular breather on top and usually it does not have a pipe to keep it above deep water. Getting water in there will damage the auto unit very quickly.
    BB454
    IF IT DOES NOT HAVE 8 PISTONS - IT'S BROKEN !
  4. Balou
    Apr 15, 2000
    207
    back to Germany
    seems I will ask some more stupid question in future,
    but its my first K5 and I'm just starting work.
    Thank God I don't have a auto trans.
    Balou
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Life is a learning prosess!
    The only stupid question is the one not asked!![​IMG]
    Ask away just give as much info as you can to what ever it is you need the info on!!
    Later
    Rock ON![​IMG] 72 K5 [​IMG]
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Hey Balou, your manual trans will have a vent too!! You need to find it and extend/repair it too. Water in there will eat the manual trans up, just not quite as fast as an auto. You may want to check/change your vital fluids.
    [​IMG] Semper Maintenance!
    [​IMG] So many ideas, so little money...
