checkin power window motors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Jan 12, 2002.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    how would i go about jumping a wire directly from the battery to the window motor to check if it is the motor or faulty wiring somewhere else???
    thanks
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I think the motor is just two prong. So just remove the plug and put a piece of small colored wire in each connector and run those out through the door. Connect those wires to a battery and it will either raise or lower it. Switching the wires on the battery will operate the window in the opposite direction.
    <P ID="edit"><FONT class="small">Edited by rampage on 01/13/02 04:09 AM.</FONT></P>
