checking crank case preasure
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Mar 8, 2002.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    how do you do that besides checking compression? I've got good compression and good power, so if i'm getting blow by it's not bad...but it'll pop a cheapo oil cap off and now I've got a breather and it'll leak around the gromet...so I'd like to check it out real good.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It sounds like your PVC (positive crankcase ventalation) is not working. You need to replace the PVC valve and make sure the hose going to it is not obstructed. You should have no pressure in the crankcase.
  3. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    sticky PCV.
    on the bright side, if you run a snorkle, your positive crankcase pressure would insure no water ingress!!!!!
    ~my other engine had broken rings, and when it was nice and warm, it would chug hot smoky blast of air outta the oil-fill BUNG.....
    huh huh, bung.............
    greg
  4. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I'm running a breather...and I've changed it twice.
  5. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    You should be running a breather and a PCV valve...
    Rene
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Most any motor will have a little bit of blow by. If your breather doesn't have a baffle below it on the valve cover, it will dirty up your valve covers fairly quick (especially if you play in the high rpm's). If your route your pcv (a good one) back into the intake, you can burn that off rather than coat your engine. It can be hard to keep those from leaking though.
