Checking resistors to see if there good!
Discussion in 'The Garage' started by backyardbuilt, Aug 16, 2004.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I have a multimeter but haven't messed with resistors in so long what do I set it at to check and see if they are good. Thanks!
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Look for the Omega symbol, should be on the dial somewhere.
  3. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
  4. tremor
    tremor Registered Member
    Mar 20, 2004
    10
    CT
    To check a resistor with a multimeter, one or both legs of the resistive element have to be removed from the circuit. If this isn't done, then other elements of a ckt will throw the reading off in most cases. When checking resistance it doesn't matter which leg you hook to which probe.
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Thanks for the replies and the chart got it fixed.
