Checking t-case output to rear axle pinion "alignment"?
Discussion in 'The Garage' started by dyeager535, Mar 14, 2005.
  1. dyeager535
    What tips and pointers can any of you offer on bolting in a new crossmember? I'm trying to make sure that I get it "square" to the rear axle, if indeed that is what I actually want/need.
    The frame isn't symmetrical I've figured out, so there is no real "centerline" I can find to use as a reference. The crossmember that was in it before I was the one who put it in, and I don't think that was in perfectly straight. In any case, it won't fit anymore, so I can't use it as any sort of reference.
    I assume in a stock application, the output shaft and pinion are as perfectly aligned as possible? With no lift, is a small amount of mis-alignment from this going to be an issue?
    With all the tolerances and wear on the truck, I'm not sure what is the best approach to make sure I get the crossmember in straight.
