checking wheel bearings
Discussion in 'The Garage' started by bryguy00b, May 22, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    can a wheel bearing still be bad if the tire doesnt "jiggle" on the hub?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes but not likely
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    o kthanx! i wanna go on this trip sunday with the 4x4 club..but my truck makes this clunky sound all the time and im not sure what it is so im a little nervuos. but the wheel bearings seems fine and the u-joints do too..but for the slip yoke on the front d-saftt..were it bolts to the front axle..its really loose..so ill need to replace that..but i should even hear that cuase it doesnt move in 2wd anyhow!? also need new tie rod ends..but other than that i couldnt find to much wrong..maybe that explains why it does it bad when turning..
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    yes they can, on my '85 C10, i had to replace a couple of studs when replaced my tires, when i took off the rotor everything was still tight. when i pulled the bearings to repack them with grease, both sides had cracked bearings. one of the rollers even came apart when we put them in the parts washer. both sides were tight when we started the day.
