Checklist: Upgrading for towing
Discussion in 'Tow & Trailer' started by BranndonC, Jan 26, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    so to prepair for towing i plan on upgrading my stock burb. Does this list sound about right for maybe once a month towing a hundred miles or so:
    14FF 4.10's
    8 lug rims i think 15 inch size if they'll fit over the 13 inch drum brakes.
    tranny cooler (the larger the better)
    tranny temp gauge
    tach
    and do i need to add a overload spring to the burb larger than what ever is there now? /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if it is mainly for towing then go with 16 inch rims. lot more highway friendly tires out there and higher load rating.
    other than that, sounds good. might want to think about 4.56 with a tallaer e rated tire.
    Grant
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I recommend the 16" E-range tires also. It's also what GM specifies for the 3/4-ton Burb... inflated to 80 psi on the rear axle. /forums/images/graemlins/thumb.gif
    Is your Burb a 1/2-ton, 3/4-ton, 2wd, or 4wd?
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    What engine and tranny do you have? There is a lot of rear overhang on a burb too so a load distributing anti sway hitch would be in order as well.
    John
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    14FF 4.10's
    tranny temp gauge
    tach
    It all depends on How much you want to invest but I would put air bags instead of more or stronger leaves.
    And weight distributing hitch.
    I just bought a 3/4ton 4x4 burb with a TD6.2 and I will be aquiring a weight distributing hitch.
    Yours is 2wd right?
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    yes mines 2wd and thanks for all the input guys, keep it comin' /forums/images/graemlins/ears.gif /forums/images/graemlins/peace.gif
  7. u2slow
    May 9, 2001
    2,217
    BC Canada
    While the brakes on a 14FF are big, they should be matched with bigger brakes up front. After all, that's where most of your braking is.
    A complete 3/4 or 1-ton front suspension can be swapped in. (No, the spindles/rotors cannot simply be swapped in). A 1-ton master cylinder and hydroboost would be a healthy asset as well.
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well on my burb since it's diesel, it has the hydroboost, but still has the 3/4 ton calipers.
    I think it should be fine anyway since my trailer should have plenty brakes and on the burb I will not go crazy with the tire sizes.
  9. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i have the 3/4 brakes now and the 1 ton master cylender for it
